Download Speed Problems (Full Member)
Postby thugsta » Mon Mar 07, 2011 10:57 am
Hey, im a donated member & get such horrible speeds, where with megaupload im not even a member & get better speeds, here it takes like an hour or more to download only 200MB (only get low speeds of 15 to about 75Kbs sometimes 117/200Kbs when i can & almost always get as high as 2MegaBYTES(ps) ), im not sure about the server but the website domain is American & so is megaupload so in theory it should be about the same speed, but since this is from a website i should get direct speed which means faster downloads.
It seems to do it for the PSX section, not sure about the other sections tho as there the only big downloads i have downloaded, small file games (like dos for example) go faster speeds then the other (psx) section.
I have tried just downloading normaly & downloading via a download manager, the manager did help slighly but it eventually stops my download & cant resume.
HELP! :bow2:
thugsta
Fav System: DOS,AMIGA,SNES,PSX
Re: Download Speed Problems (Full Member)
Postby Hot Trout » Mon Mar 07, 2011 1:36 pm
You need to stop using the download manager. This site is designed to penalise anyone using download managers to obtain roms. Simply log in to the roms section and start your download as per normal.
Users browsing this forum: No registered users and 249 guests
