Daphne crc errors
Daphne rom crc errors
Postby pstshanesaw » Sun Jan 30, 2011 2:40 am
Hi guys, i am trying to download cobra command and astron belt for daphne. they seem to download fine but when i try and extract them i get crc errors. I have tried using winzip, winrar, 7zip and winace but have had no luck. I have also tried to redownload but i get the same error. Any help would be much appreciated.
Cheers
pstshanesaw
Re: Daphne rom crc errors
Postby Hot Trout » Sun Jan 30, 2011 5:18 pm
What size is the cobra rom. I can check to see if it is corrupt.
Postby pstshanesaw » Sun Jan 30, 2011 7:47 pm
Hi, the astron belt zip file is 627mb and the cobra command zip file is 1.25gb.
Cheers
pstshanesaw
Postby Hot Trout » Sun Jan 30, 2011 11:36 pm
The file sizes you have are correct. So based on what you said I went and checked the versions that I have and discovered that they also are corrupt with a CRC error in both ZIP files. :thumbdown:
I am going to check my archive tapes to see if I have a raw copy of these disk images somewhere. If I still do then I could re-zip them and upload them again. This will take some time so please give me a day or two to do this.
If you dont hear back from me by Friday please bump this topic again to remind me.
Thanks for the heads up on this :good:
Postby pstshanesaw » Mon Jan 31, 2011 6:08 am
Awesome. Thanks m8
pstshanesaw
Postby pstshanesaw » Mon Jan 31, 2011 8:47 pm
Hi m8, Just tried cliff hanger re encoded and it has the same problem.
pstshanesaw
Daphne crc errors
Postby pstshanesaw » Fri Feb 04, 2011 9:19 pm
Hi guys, I am still having trouble with crc errors on some of the daphne roms. I have downloaded cobra command, astron belt and cliff hanger but i get crc errors in all of them. Any help would be much appreciated.
Cheers
pstshanesaw
Re: Daphne crc errors
Postby Hot Trout » Sat Feb 05, 2011 12:45 pm
Just so that everyone knows, there are known errors on three of the Daphne images causing a CRC when you try to unpack the zip.
I can not find the originals at the minute and am unable to create them again to upload. I promise that this will be done in the next week or so.
Sorry for this but it is most likely due to the sheer size of the zip files in question. Stay tuned and if you hear nothing in a few days please bump this topic again.
Postby pstshanesaw » Sat Feb 05, 2011 2:27 pm
Hi m8, just tried firefox as well and get the same errors. Just a heads up. I will try the others and report back.
pstshanesaw
Postby Hot Trout » Sun Feb 06, 2011 1:14 am
Topics Merged :
BTW, once you have checked them all please list all the roms that need replaced. This will help me a lot. Thanks.
Users browsing this forum: No registered users and 160 guests
