Jackal.nes might be a bad rom ...
Postby rundosrun » Fri Jul 15, 2016 10:38 pm
Hi, I downloaded Jackal.nes, loaded it up on my original Wii, and when I clicked on it the screen froze. The Wii wouldn't even power off; I had to unplug it from the wall. I had actually tried this some time long ago and it did the same thing. I think I had to reinstall the HBC because it started having weird problems. (I tried it again because I wasn't sure if I'd downloaded it here.) This time it so far doesn't appear to have damaged the Wii at all, but I'm afraid to attempt loading it again. Of course this has never happened on my Wii with any other game. So I wanted to see if you guys can find any problems with it on your end. Thanks.
rundosrun
Steam ID: http://steamcommunity.com/id/
http://steamcommunity.com/id/" target="_new"> http://steamcommunity.com/id/.png" border=0 width=160 height=45>
Re: Jackal.nes might be a bad rom ...
Postby Kherr » Tue Jul 26, 2016 11:29 pm
Hi rundosrun,
I just tried running Jackal (USA).nes from the Single Mega Pack in the Nintendo section and it worked fine in JNES for the PC. I will try downloading the normal version here in a second and testing for viruses, etc. as well as loading it in JNES. Please bear with me while I test this. Thanks!
Best Regards,
Postby Kherr » Tue Jul 26, 2016 11:41 pm
Hi rundosrun,
I just downloaded and checked on the USA folder of the NES ROMs and found Jackal.nes working without issue. I noticed in the GoodNES libraries we have quite the few different copies of Jackal. Can you please let me know which one you may have downloaded? Thanks!
BTW, Jackal was one of my childhood favorites on the NES. :hi:
Best Regards,
Postby rundosrun » Wed Jul 27, 2016 4:24 pm
I got it from the USA folder.
http://www.theoldcomputer.com/roms/getf ... thbC56aXA=
If I choose to try one from the GoodNES libraries which one do you recommend? I haven't downloaded those types of roms in a while so I've forgotten what all the syntax means. Thanks.
rundosrun
Postby Kherr » Fri Jul 29, 2016 6:22 am
Users browsing this forum: No registered users and 252 guests
