Trying to find Enchanted Forest - 4VXFC818 ROM eforesta.zip
Postby RRicci » Sun Mar 22, 2015 4:32 pm
I've tried looking on here on several MAME directories, but no luck. Could someone direct me as to where to go?
RRicci
Been thanked: 26 times
Re: Trying to find Enchanted Forest - 4VXFC818 ROM eforesta.
Postby Hot Trout » Sun Mar 22, 2015 7:21 pm
Erm, go to Roms, then scroll down to mame. In there you will find the largest online collection of mame sets anywhere on the Internet.
Postby RRicci » Sun Mar 22, 2015 7:43 pm
Hot Trout, I tried doing that, and no luck. I tried roms, then several Mame listings with no luck.
I've tried the following folders: o.148u5, 0.72, 0.36, and 0.31.
RRicci
Postby Hot Trout » Mon Mar 23, 2015 10:45 am
OK we have several copies of eforesta.zip as follows
Mame-0.137\e
Mame-0.139\e
Mame-0.139u1\e
Mame-0.140\e
Mame-0.144\e
Mame-0.155\e
I am not sure why you are unable to find these?
Postby RRicci » Mon Mar 23, 2015 3:11 pm
Hot Trout wrote:OK we have several copies of eforesta.zip as follows
Mame-0.137\e
Thank you, Hot Trout, It worked. But the rom is bad (not this board's fault), but at least I'm getting closer to having a full set.
I consider this closed now. :)
RRicci
Postby Kherr » Mon Mar 23, 2015 4:29 pm
I'm glad you were able to find it RRicci. This seems to be the second ROM you've found in our database that isn't working correctly. I do apologize for hearing that. Hopefully we can find a working version for you to be able to add to your collection. :hi:
Postby Hot Trout » Wed Mar 25, 2015 5:56 pm
Kherr wrote:I'm glad you were able to find it RRicci. This seems to be the second ROM you've found in our database that isn't working correctly. I do apologize for hearing that. Hopefully we can find a working version for you to be able to add to your collection. :hi:
Just to be clear, our roms are exactly as dumped for MAME. All other versions will be the same.
Users browsing this forum: No registered users and 57 guests
