Can't get roms to work with Mame 0153b 64bit
Postby TungstenX » Thu May 15, 2014 2:15 pm
Hi All,
I'm new to this. I'm running Windows 7 64bit and downloaded and installed Emulators/MAME/WIN/MAME/MAME-v0.153/mame0153b_64bit.exe. I've downloaded a few roms form Roms/MAME/Mame-0.153/0.152 to 0.153 Updates/ but so far, none works. (I unzip them to the roms/[rom_name] where [rom_name] is the same as the .zip file name)
(Btw, what does the 0.152 to 0.153 Updates mean? Should I hunt for the rom in earlier versions and update it?)
Please help.
TungstenX
Re: Can't get roms to work with Mame 0153b 64bit
Postby TungstenX » Fri May 16, 2014 12:17 pm
Is there anything that I have to download/load to get the games to work? Is there a way to see why they are not working?
TungstenX
Postby devilchi » Fri May 16, 2014 7:17 pm
Ok with Mame first you do not have to unzip the files. They should remain zipped.
Second, you are downloading games from a update set. That means most of the files needed for each game are not present. If you download something like mameui
LINK HERE
http://www.theoldcomputer.com/emulators/index.php?folder=MAME/WIN/MAMEUI/MAMEUI-v0.153
and then run a audit on your mame rom dir. It will tell you what is missing. You could also use a program called "clrmamepro" to check all your roms.
LINK HERE
http://mamedev.emulab.it/clrmamepro/
NOTE: If you do please read a good tutorial because you can damage your files if you check the wrong options. I hope one of these two hints help. If not just post back and will go thru some more steps.
P.S. If you are trying to run newer arcade games. Some may require a CHD file. This is a compressed image of the hard drive from that arcade game. These are large files usually and most of the time require a beefy pc to even start up let alone play. My I7 with 2 680 nvidia sli graphics cards and 32 gig of memory struggle with a few. But again some games require these additional files.
devilchi
Next LVL Up at : 25
Next LVL Up at : 25
Has thanked: 7 times
Been thanked: 9 times
Fav System: There is a bad one?
Postby TungstenX » Sat May 17, 2014 2:58 pm
Thank you devilchi. I've manage to get a few roms from 0.144 to work with MamePlus 5149. I see it has a UI program but I'm not sure how to use it.
Should I just place the zip file in the rom folder? Or use the UI program? I'll have a look at your links a bit later on.
TungstenX
Postby devilchi » Sat May 17, 2014 9:05 pm
Never used MamePlus but your unzipped roms should go in your rom dir. You will also need to get the version of mame that goes with the rom set you are using. Each version of mame was made for a exact set of roms. if you have the 0.144 rom set you will need mame 144. Roms get renamed and added/deleted each edition so you have to have the proper sets for your version of mame. I try to always use the current. Which I believe is .153 If you really get into mame then you will use the above program. clrmamepro to constantly update your collection. There is a little learning curve with these but in the end it is usually worth it. NOTE: Also a lot of games also require a bios file to be present in your rom dir. Again i suggest clrmamepro to check these as it will tell you what "system" files are missing. If you can not get things going yell and Ill download your version and do a install and see what is what.
devilchi
Next LVL Up at : 25
Next LVL Up at : 25
Postby SpydorKat » Fri Jan 02, 2015 12:27 am
I have a Question about DIE HARD ARCADE MAME ROM. I want to Play it on Seleuco's MAME v139u1 for Android. Is This Possible?
SpydorKat
Fav System: SegaCDX + PSOne =)
Steam ID: solidspider
Users browsing this forum: No registered users and 331 guests
