Sharp Twin Famicom BIOS .bin to .nes?
Postby semerl » Wed May 14, 2014 5:56 am
Is it possible to convert a .bin file to a .nes file?
semerl
Re: Sharp Twin Famicom BIOS .bin to .nes?
Postby Hot Trout » Wed May 14, 2014 10:01 am
The .bin can be extracted and maybe this would work for you. Try extracting the .bin to a .nes. I have not needed to do this myself but in theory it should work.
Postby semerl » Wed May 14, 2014 10:41 am
How does one extract a .bin?
semerl
Postby crustyasp46 » Wed May 14, 2014 1:24 pm
semerl wrote:How does one extract a .bin?
This site may answer your question : [code]http://www.tech-recipes.com/rx/696/how_use_open_bin_cue_iso_files/[code]
Postby Dragon Mech » Wed May 14, 2014 3:00 pm
oops. crusty missed a "/" in the code.
there. thats better :bowser:
Postby semerl » Wed May 14, 2014 9:12 pm
*sigh* We're talking about a .bin file with no .nes equivalent that won't work in Nestopia. I already tried renaming the .zip and .bin to .nes. That didn't work.
semerl
Postby Dragon Mech » Thu May 15, 2014 2:57 pm
ok. first off. i want to show every one what a Twin Famicom is:
http://en.wikipedia.org/wiki/Twin_Famicom
next, the BIOS (.bin) file is used by what ever emulator that supports it, to function more like a twin famicon (probably for the FDS emulation), the same way a Sega Genesis emulator needs BIOS files to emulate a 32X or a SegaCD. this means that the .bin (BIOS) file can't be played like a game file (.nes, .fds etc).
Postby devilchi » Fri May 16, 2014 7:40 pm
Ok, I understand why emulators need (bios) files and the .bin extension. I have many emulators I'v had to track bios files for. What I do not understand is what is the end goal here? Are you trying to run the bios as a game? As you said most systems need the .bin to run games, you usually do not run the bios itself. Please clarify the end goal and I will try to help if I can.
devilchi
Next LVL Up at : 25
Next LVL Up at : 25
Has thanked: 7 times
Been thanked: 9 times
Fav System: There is a bad one?
Postby semerl » Fri May 16, 2014 11:39 pm
Every time I try to use a .bin as a bios in Nestopia (Undead edition 1.44), an error message manifests saying "No valid file in archive!".
semerl
Postby semerl » Fri May 16, 2014 11:40 pm
devilchi wrote:Ok, I understand why emulators need (bios) files and the .bin extension. I have many emulators I'v had to track bios files for. What I do not understand is what is the end goal here? Are you trying to run the bios as a game? As you said most systems need the .bin to run games, you usually do not run the bios itself. Please clarify the end goal and I will try to help if I can.
What I want is an adjustable experience.
EDIT: ...And a more hipster-ish one.
semerl
Users browsing this forum: No registered users and 299 guests
