emulator and rom
emulator and rom
Postby berzerkdream » Wed Apr 09, 2014 5:52 pm
I downloaded mameui64 0.153 and have tried the 0.31 400 pack rom as well as others 0.152, 0.151 etc. I can't get any of them to work or even show up in the audit.
I'm not completely new to this but still consider myself a noob. I currently have mameui32 0.136 which I've been running without any problems for years.
What am I missing?
berzerkdream
Fav System: Atari
Re: emulator and rom
Postby silent sniper » Fri Apr 11, 2014 6:00 am
hello and welcome
for mame to work correctly you need the proper roms for the proper version of it.
so 0.148 roms "might" work on 0.153,but to have a working set you need to match the version you play to the version you download.
i think we have here the 0.150 set but im not sure,you need to ask hot trout or look for it in the news section.
silent sniper
Next LVL Up at : 150
Has thanked: 23 times
Been thanked: 61 times
Fav System: sony playstation
Postby berzerkdream » Fri Apr 11, 2014 4:21 pm
Thanks for response.
I tried different emulators matching them exactly with rom versions with no success until...
Rom problem solved. 1) When I unzipped the downloaded roms, they automatically populated sub-folders based on their names (folders; a, b, c etc.) The emulator apparently doesn't recognize sub-folders so I removed roms from the subfolders and added them individually to the roms folder. 2) Within opened emulator I went to "options", "directories", "browse" and connected mameui64 roms. 3) Audit as usual. Success!
New problem. (system windows 7 directx 11) I've run diagnostics on directx, everything okay. The games run, sound okay, coins deposited, game started etc. but screen is blank. Blank on prompts, everything. I've checked other forums with inconclusive answers being directx or graphics card issues. No real answers so far except replace graphics card which would be last resort. I'll keep searching for answers.
Do you know why screen is blank? Have you heard of or encountered this problem?
Problem #2 (just discovered). Within emulator "default game properties" I can't change any of the settings. Check boxes, "apply" "okay" and it reverts back to original settings.
berzerkdream
Fav System: Atari
Postby berzerkdream » Fri Apr 11, 2014 6:13 pm
Problem #2 solved. Recycled emulator and downloaded same version. Changing the setting HLSL etc. doesn't help with problem #1.
Problem #1 still a work in progress.
berzerkdream
Fav System: Atari
Postby Hot Trout » Fri Apr 11, 2014 6:23 pm
Thanks for letting us know you got it working, its great to get feedback from the members.
Postby berzerkdream » Fri Apr 11, 2014 7:26 pm
Problem #1 solved. "Options", "default game options", "display", "videomode GDI"
berzerkdream
Fav System: Atari
Users browsing this forum: No registered users and 253 guests
