Getting Dreamcast games to work.
Postby DOS76 » Tue Mar 04, 2014 1:40 am
Hi I am new to the site but not to emulation I have been a fan of retro gaming since before it was retro gaming. I have never had any issues using the older systems I suppose because they are more simple they are easier to use. Today I took my first shot at emulating Dreamcast and I seem to be having issues with the game I downloaded not being in any form that MakaronEX recognizes. I tried using both the unzipped and zipped file but still not luck. Anyone know what I might be doing wrong and how to fix
DOS76
Steam ID: http://steamcommunity.com/id/the dos76
http://steamcommunity.com/id/the dos76" target="_new"> http://steamcommunity.com/id/the dos76.png" border=0 width=160 height=45>
Re: Getting Dreamcast games to work.
Postby silent sniper » Tue Mar 04, 2014 7:41 pm
hello there mate
makron is more suited for arcade boards based on the dreamcast (NAOMI) then for casual dreamcast emulation.
there are two good emulators for "normal" dreamcast gaming.
1) Demule,strong emulator that can play NAOMI 1/2 games as well as other systems,not very user frindely since the team translated it from Russian.
2)NullDC,good,fast,play nearly all games.
the "trick" is to use the latest svn build and not the last official stable version on the project homepage.
follow the white rabbit at: http://www.emucr.com/2013/03/nulldc-svn-r150.html
edit: don't forget to set the right bios for the right region of the game you try to play,you can "patch"/set it to auto region in the config menu.
also don't forget to set up the vmu (memory card) or you wont be able to save.
silent sniper
Next LVL Up at : 150
Has thanked: 23 times
Been thanked: 61 times
Fav System: sony playstation
Postby DOS76 » Wed Mar 05, 2014 5:52 am
Thanks! Do you know if they explain how to set up the VMU I don't know anything about it but if there are good text instructions I can do just about anything its just a matter of learning.
DOS76
Postby silent sniper » Wed Mar 05, 2014 11:23 am
start the emulator
go to the config menu
choose the vmu/memory card config sub menu.
add 1 or 2 vmus
close and save/press apply
choose boot>no disc.
on the system screen go to memory card and do a format,adjust the icon of the vmu.
you're done
enjoy
silent sniper
Postby Hot Trout » Wed Mar 05, 2014 12:20 pm
Thank you silent for your input. Good to see you still around with your knowledge.
Postby silent sniper » Thu Mar 06, 2014 1:01 pm
thanks ht :thumbup:
i lurk the forums from time to time.. :wink2:
still building my ps1 redump set.
Finshed:
dreamcast
neo geo cd
gamecube
sega cd
silent sniper
Users browsing this forum: No registered users and 241 guests
