Corrupt file
Corrupt file
Postby connorsdad » Mon Jul 15, 2013 8:50 am
Not sure if this is the right place to post so I apologize in advance. Mad Dog 2 - The Lost Gold.7z in the daphne laserdisc section is corrupt.
connorsdad
Fav System: Amiga 500
Re: Corrupt file
Postby PMJPlay » Mon Jul 15, 2013 11:04 am
Thanks for the head's up :D I am sure HT will look into it when he has a chance...
Re: Corrupt file
Postby Hot Trout » Tue Jul 16, 2013 11:37 am
Hi and welcome. I checked the file and it appears to be working ok for me. Please try downloading it again and if that fails come back to me at this topic again.
Thanks.
Re: Corrupt file
Postby Hot Trout » Tue Jul 16, 2013 10:16 pm
Update, we found errors inide the archive which must be causing the problem. Thanks to a generous member a new version shoul be availabe later this week. Stay tuned.
Re: Corrupt file
Postby connorsdad » Sun Jul 28, 2013 6:19 pm
Hot Trout wrote:Update, we found errors inide the archive which must be causing the problem. Thanks to a generous member a new version shoul be availabe later this week. Stay tuned.
Any news on the new version ?
connorsdad
Re: Corrupt file
Postby Hot Trout » Sun Jul 28, 2013 7:21 pm
Yes that rom was replaced with the working version. I forgot to update this post because there was another post about it as well. Go ahead and download it.
Re: Corrupt file
Postby connorsdad » Mon Jul 29, 2013 12:53 pm
I've just downloaded the file again and its still corrupt :?
http://www.theoldcomputer.com/roms/getf ... BHb2xkLjd6
connorsdad
Re: Corrupt file
Postby Hot Trout » Mon Jul 29, 2013 5:28 pm
My BAD :roll: :problem: , I forgot to move the new file over once I had copied it up. Sorry for making you download that again. The new file is now in place (you tell from the different file size) so go ahead and download now.
Maybe now you will be able to enjoy it,
Users browsing this forum: No registered users and 112 guests
