problems with downloading link.
Postby superflyblaze » Tue Jul 02, 2013 5:51 am
I downloaded a rom but it was a htm address that dont do anything, I have unlimited access,I should have no problems....
superflyblaze
Fav System: between n64 and ps3
Re: problems with downloading link.
Postby Hot Trout » Tue Jul 02, 2013 9:48 am
Please explain more fully. Can you also provide a link to the section or rom that did not work.
Postby NkNkNK » Sun Sep 01, 2013 11:23 am
Same here just the adress htm . Im unlimited user but none of the 0.139 roms work. Even one rom of pc wngine doenst work
NkNkNK
Postby Hot Trout » Sun Sep 01, 2013 3:33 pm
This is most likely a browser issue. If when you try to download a zip file your browser shows code then the settings locally on your computer are wrong. To test just download an alternative browser and try again.
Users browsing this forum: No registered users and 112 guests
