Daphne question
Daphne question
Postby MNMax21 » Wed Apr 24, 2013 7:33 am
There are two parts to a large majority of the daphne laser disc image files. I am wondering how I combine the two once I put them in the frame file location?
MNMax21
Fav System: MAME
Re: Daphne question
Postby Hot Trout » Wed Apr 24, 2013 11:39 am
They are seperate parts of the 7zip file. Download ALL parts of the archive into the same folder on your computer. Then unzip or unarchive the first part into a new folder and all the parts will be used.
You need ALL parts of the archive for it to work. The reason for multiple archive parts is the size of the files.
Users browsing this forum: No registered users and 222 guests
