Bad NES Super Mario Brothers rom?
Postby arinlares » Wed Sep 29, 2010 5:46 am
Several times, I've downloaded the Super Mario Brothers NES rom (there's even a download pack with everything), and I keep getting the same glitched (read, unbeatable), undersea level hack. I can't locate a real working download, but the bad rom is here.
The same bad rom is also in the mega download pack.
arinlares
Been thanked: 5 times
Re: Bad NES Super Mario Brothers rom?
Postby JAHGoVeg » Wed Sep 29, 2010 4:01 pm
huh. I will try that now so it's Super Mario Bros 1 NES
this one right?
http://www.theoldcomputer.com/roms/getf ... UyMDEuemlw
Postby JAHGoVeg » Wed Sep 29, 2010 4:14 pm
That is so Wierd! Using Mednafen Emulator it shows me the water level, But when I Use Nestra which doesn't support sound I get the Regular game. maybe it has something to do with the emulator
Here try this.
Postby JAHGoVeg » Wed Sep 29, 2010 4:24 pm
for whatever reason Uploading .nes files are not allowed even in private messages so instead I'll send you the link from where i got it. ;)
Postby arinlares » Thu Sep 30, 2010 12:27 am
I run it through Nestopia, and even had a problem on a DS NES emulator, the name of which I can't remember. The rom you linked works, but it's running into an issue with NTSC/PAL conversion. I'll try to find a US one.
arinlares
Postby JAHGoVeg » Fri Oct 01, 2010 8:44 pm
k
Postby papasforever » Sun Jul 10, 2011 7:29 pm
I second this problem.
I tried the rom to Nestopia and Fceux and it had the same problem (showing the stage with the water) :freakout:
papasforever
Postby Charon33 » Sun Oct 09, 2011 4:16 pm
I've had this same problem. Tried using the rom for SMB + Duck Hunt and this seems to run perfectly fine for SMB.
Charon33
Fav System: NES
Postby Kherr » Tue Oct 11, 2011 12:35 am
I'm actually kinda shocked that HT hasn't posted in this yet. I would test this out for you and confirm it myself, but I kinda re-formatted my pc to Windows 7 Pro just a little bit ago and as such have no emulators or games currently installed. When I get around to installing them I'll be sure to check this out.
Users browsing this forum: No registered users and 148 guests
