Mame4ios
Mame4ios
Postby Jockmcd » Sat Mar 16, 2013 12:42 pm
Guys I'm baffled with roms for mame4ios , I have an ipad 3 jailbroken , downloaded a full set of 0.139 roms on my computer installed Openssh on ipad along with winscp on computer , ive put all roms in the correct folder I.e mobile,media,roms,mame4ios , it shows no roms at all in the emulator ? I do have imama4all & IFBA emulators aswell they are working ok.
I have seen that only 0.139u1 romset works with mame4ios is the 0.139 romset the same or different ? If should be able to use the 0.139 romset what am I doing wrong why won't they load ?
Jockmcd
Fav System: All 80's
Re: Mame4ios
Postby Jockmcd » Tue Mar 19, 2013 10:12 pm
Guys c'mon, should 0.139 roms work in mame4ios ? I have a whole set of roms but none of them load?
Jockmcd
Re: Mame4ios
Postby crustyasp46 » Tue Mar 19, 2013 11:06 pm
:bump: :anyone:
Re: Mame4ios
Postby SE7EN » Wed Mar 20, 2013 5:32 am
crustyasp46 wrote::bump: :anyone:
sorry, I am useless outside of computers.
Re: Mame4ios
Postby Hot Trout » Wed Mar 20, 2013 7:37 pm
Jockmcd wrote:Guys c'mon, should 0.139 roms work in mame4ios ? I have a whole set of roms but none of them load?
Mame 0.139 roms will and do work with MAME4iOS emualtor. It prefers the 0.139u1 set but that is only for a few roms.
Re: Mame4ios
Postby Jockmcd » Wed Mar 20, 2013 8:37 pm
Thank you HT, for anyone that is having problems with imame4ios I just realised what I was doing wrong and hope this may help:
When I downloaded a few times from cydia the mame4ios app it only included the mame4ios folder with a docs folder inside it eg. When in ifile it would be var/mobile/media/roms/MAME4IOS (which is where the roms should be placed or so I thought) inside the MAME4IOS folder there was only 1 folder called docs, I did not place my roms in the docs folder but inside the MAME4IOS folder , it turns out there was an update last night on my Mame4ios cydia update so I installed and when I went to look at any changes to my amazement inside the previously installed Mame4ios folder there was more than just a docs folder infant maybe 10 or so and 1 of these was named ROMS , I placed my roms in here and now they work (not all of them but most of them) so if any 1 is having trouble playing roms just to clarify either update or remove and reinstall mame4ios use ifile and place roms in here:
Var/mobile/media/roms/mame4ios/ROMS - place games in the last folder, they should work, make sure to reboot device after any updates, reinstalls and placement of games to the folder just to be sure, hope his helps anyone with rom problems.
So for my next questions:
Is there a list anywhere of the actual working games list to download or view anywhere ( not the games themselves but just the working names on a list ) ?
Threre are a lot of games in the app which are unhighlighted and a lot which are highlighted they are either light grey or white but both types load and work ? What's the difference here can anyone explain ?
Will a clone in general be worse than the original or are they just as good ?
Cheers all I hope I can help people with my above solution if you we're in the same position as me, likewise I hope you can maybe answer my questions above.
Thank you.
Jmcd.
Jockmcd
Re: Mame4ios
Postby Kherr » Wed Mar 20, 2013 11:51 pm
I'm glad you figured out how to solve your dilemma Jockmcd. I am completely useless when it comes down to mame, and even more useless when it comes down to Apple products. :hi:
Users browsing this forum: No registered users and 222 guests
