ROMs don't unzip properly
Postby alosenster » Sat Sep 04, 2010 3:55 am
I dled a few nes roms - mario 1, 2 & 3, zelda 1, etc. and they worked fine. They unzipped to reveal a folder with the .nes files in them.
Then I ran into some problems. I started dling some sega roms, and none of them would unzip properly. I would get an infinite loop of zipped folders ending in .zip or .bin or .bin.cpgz. Any idea why they don't just unzip? This happened with a few sonic roms and some others. I haven't been able to get any sega roms opened. Some nes roms did the same thing.
Thanks.
alosenster
Re: ROMs don't unzip properly
Postby Guest » Sat Sep 04, 2010 4:01 am
could you make a list of some of the exact titles that did this. ill take a look when I get off :)
Postby alosenster » Sat Sep 04, 2010 4:13 am
For starters, I tried every Sonic rom on the top 10 for Sega Megadrive with the same outcome. Let me know if you need more than that.
alosenster
Postby Guest » Sat Sep 04, 2010 5:50 am
Hmm. I just downloaded the top 10 and the only problem I had was with #6 Mortal Kombat 3 (4) [h4].zip and it was corrupt which happened. All the other ones extracted just fine and were all .bin files. Do you use WinRar?
Postby alosenster » Sat Sep 04, 2010 2:45 pm
No, I'm using a Mac. But this is the first time I've had trouble unzipping something. I'll give it a shot on my PC laptop if you think it would make a difference.
alosenster
Users browsing this forum: No registered users and 203 guests
