Bios help for a reward!
Postby Deputy » Wed Jan 30, 2013 11:30 pm
Hey
I did a search but couldnt find a thread on this yet. Im obviously very green with MAME stuff but Im starting to get the lay of the land. An issue Im having is with Cave/Atlus roms. Im using the correct romset (139s) but they are not appearing.
Am I correct in thinking this could be due to a missing bios?
Do bios need to correspond to the romset? ie. neogeo bios for .139s would be different to the same bios of .144s
Is there a rough outline of which bios refer to which particular company/catalogue of games?
Reward for Answer: Every following post that is made by the successful answererer will receive a slow approving nod from myself. Forever.
Deputy
Fav System: N64
Re: Bios help for a reward!
Postby SE7EN » Thu Jan 31, 2013 12:28 am
you can right click the list of games, on an individual rom, and choose 'audit' this will tell you what you have or don't have and I believe also any discrepencies in files you have but are not correct version (I don't think it'll tell you what version you have, simply size:xx size found:yy or soemthing similar, been awhile since i booted up MAME)
Postby Hierophant » Thu Jan 31, 2013 9:14 am
Deputy wrote:Hey
No, that is incorrect for the Cave/Atlus games DoDonPachi, DonPachi, ESP Ra.de., and Guwange. These games do not have a BIOS. Like SE7EN advised, you can audit games to check what is missing.
Deputy wrote:Do bios need to correspond to the romset? ie. neogeo bios for .139s would be different to the same bios of .144s
Basically, yes, BIOS files need to pass audit for the particular MAME version number being used, the same as ROMs.
Deputy wrote:Is there a rough outline of which bios refer to which particular company/catalogue of games?
There is an exact outline in the MAME GUI itself. In the left pane of the GUI there is folder called BIOS. Expand it see all the BIOS systems and their associated game lists.
Hierophant
Next LVL Up at : 25
Next LVL Up at : 25
Has thanked: 7 times
Been thanked: 25 times
Fav System: Neo-Geo
Users browsing this forum: No registered users and 222 guests
