Controller help for playing ROMs
Postby darren77 » Wed Sep 26, 2012 9:50 am
Hello.
I was wondering if a regular PC game controller will work for playing NES ROMs. Is a special controller required or ?? I had a problem to switch from my keyboard to using my USB controller and I'm not sure why.
I noticed in the emulator menu I could not select the joystick option. Maybe my controller is not compatable?
If anyone has any suggestions, I'd greatly appreciate it!
darren77
Next LVL Up at : 15
Next LVL Up at : 15
Has thanked: 4 times
Fav System: NES
Re: Controller help for playing ROMs
Postby SE7EN » Wed Sep 26, 2012 2:43 pm
If your controller is detected by your OS, it should work in your emulator (make sure you have drivers installed). If all else fails, you might want to try controller profile software such as Xpadder. You would set your emulator up to use keyboard, then use the program to make the buttons on your controller emulate keyboard presses.
Users browsing this forum: No registered users and 152 guests
