How to install PC98 games?
Postby PMKMDL » Fri Aug 31, 2012 6:34 am
I'm new in PC98 emulation and I have problem with instaling some games(Kakyusei for example). I've created blank .hdi file in anex, formated and partitioned with dos system disk and... install.exe (or whatever) in one game work in another don't. (I'm using FILMNT, I'm not familiar whit dos comands). Is there some guide for newbies how to use PC98? Link please? Cuz many roms req install.
Sorry for bad english
PMKMDL
Re: How to install PC98 games?
Postby Kherr » Fri Aug 31, 2012 8:59 am
I'm not the guy that can help you with this issue, but I wanted to say thanks for joining the forums! Hopefully someone can get back to you as soon as possible to help you with your issue. I know seeing the thread with a new post kinda gets your hopes up, sorry! Just wanted to say welcome, and that someone will most likely be able to answer your question pretty quickly.
Come on guys, let's get to it! :D
Postby Hot Trout » Sat Dec 08, 2012 5:12 pm
If the files are small which they should be then you can upload them in the forums when you post. That would be a great way to start.
Welcome by the way.
Users browsing this forum: No registered users and 142 guests
