Countdown pc rom error
Postby astover1979 » Tue Jul 06, 2010 7:15 am
i downloaded the pc rom Countdown but rom will not run in vista. i do not know what to try to make it run~
astover1979
Re: Countdown pc rom error
Postby Hot Trout » Tue Jul 06, 2010 9:26 am
You will need to run it in XP Compatable mode.
Start by reading this Microsoft Article on how to use compatability mode. Then also take a look at this article on games in Vista. You may need to look at DosBox or the like.
Hope this helps yuou out a little.
Postby astover1979 » Wed Jul 07, 2010 12:18 am
dosbox worked great..requires alot of dos knowledge.. but it works!
astover1979
Postby Hot Trout » Wed Jul 07, 2010 10:03 am
Good, gald to have helped. In our new emulators section we will be covering DosBox and all its add ons. Stay tuned.
Postby astover1979 » Thu Aug 12, 2010 11:43 pm
new error.. half way tru rom.. i get a memory error and it kicks me from game..
astover1979
Postby Hot Trout » Fri Aug 13, 2010 10:14 am
If the PC games is running then the rom is good. It sounds more like a gold old PC game. Which game are you playin.
Postby astover1979 » Fri Aug 13, 2010 10:37 am
really just that one.. i tried dune II but dont have a maual for the lock on it ..mean streets seemed to run ok...
astover1979
Postby Hot Trout » Fri Aug 13, 2010 2:31 pm
The difference is that the PC Roms are not actually Roms as such but archives of the games. You cant have a bad dump with the PC games, if they install then they are as their were originally. If you have errors/problems they were probably present in the game from the start.
Postby astover1979 » Fri Aug 13, 2010 4:07 pm
2 problems.. countdown doesnt install.. and i have played past this part in it before..worked fine
astover1979
Postby Hot Trout » Fri Aug 13, 2010 4:13 pm
Im not sure then what is wrong. It could be settings in DosBOX. Try working with that instead. If lost you could always ask Google.
Users browsing this forum: No registered users and 204 guests
