problems with SIT files
Postby Dragon Mech » Fri May 11, 2012 1:01 pm
ok, i've got two problems and they are on the same page so i figured i could be efficent and put them in to one post. 1st: i noticed that the majority of the macintosh game roms are in .sit format. i tried to decompress "beyond zork.sit" with winzip an 7-zip but neither of them could do it. 2nd: i downloaded "Games_Compilations_8.zip" from the macintosh game page and both winzip and 7-zip said that the file was not a valid file.
Re: Two problems, One shot
Postby silent sniper » Fri May 11, 2012 4:12 pm
silent sniper
Next LVL Up at : 150
Has thanked: 23 times
Been thanked: 61 times
Fav System: sony playstation
Postby Dragon Mech » Sat May 12, 2012 9:26 am
thanks sniper, i now know what a .sit file is but it i still can't get them in to a MAC 2 disk image so i can decompress them.
Postby silent sniper » Sun May 13, 2012 9:21 am
glad it helped you
well im not a big fan of apple so i don't know about apple emulators and apple related stuff.
im sure HT can land a hand if you ask him.
silent sniper
Re: two problems with 2 apple roms
Postby Dragon Mech » Mon May 21, 2012 12:20 pm
i did some hunting around the MAC emulation sites and found Stuffit for windows and the program
HFVexplorer. but when i decompressed the SIT files and loaded them to a MAC HDD file, i found the decompressed files were useless. i couldn't even get the readme files to open. this problem is giving me a headache. :headbang:
Re: problems with SIT files
Postby Dragon Mech » Tue May 22, 2012 2:51 pm
i downloaded a different SIT file expander but i'm sitll having the same problem. non of the expanded files
work. can anyone help with this problem? :anyone:
Postby Hot Trout » Tue May 22, 2012 3:38 pm
If you are already using stuffit to look at these then you are in the right direction. It is possible that they were corrupt already. I think it was te_lanus that uploaded these files. I am downloading them now to see if I can find anything with them.
te_lanus, could you have a look at this for me?
Postby Dragon Mech » Wed May 23, 2012 10:05 am
thank you HT, any help would be greatly appreciated
Postby Dragon Mech » Thu May 24, 2012 10:07 am
it looks like i solved my own problem, or problems. first i messed up the installation of MAC OS 7.5 on one of my HDD images for Basilisk II. second i was going about expanding the SIT files in the wrong way.
so i reinstalled MAC OS 7.5 and installed stuffit expander 5.5 on the HDD image. next i enabled the external
file system fuction of basilisk II in the GUI. then i ran basilisk II and accessed the drive that i had stored the SIT files on. it worked, the icons of the SIT files had changed from useless, meaningless data to fully usable
files that worked perfectly. all i had to do was change the destination file during file expantion and save.
also, i stopped useing stuffit expander for windows and switched to the Aladdin expander 5.0 for windows. stuffit required a regestration number and i felt like if i kept useing it it would stop working after a while.
Postby Hot Trout » Thu May 24, 2012 11:48 am
Good to hear and thanks for letting me know.
Users browsing this forum: No registered users and 152 guests
