Decompression error
Decompression error
Postby Dragon Mech » Wed Apr 25, 2012 2:49 pm
i downloaded the GBC file: Harvest_Moon_GBC_2_(U)_[C][!][1].zip and when i went to decompress it i got
an error message. i have winzip 10.0 and 7zip 9.25 alpha and i tried to decompress the rom with winzip 8.0 and 7zip 9.21 beta as well. 7zip says that an unsupported compression method was used to creat the zip file.
so i'm wandering if any one has had the same issue and if they were able to fix it?
Re: Decompression error
Postby Hot Trout » Wed Apr 25, 2012 4:46 pm
I tested this rom again and it seems to work for me. Can some of the other guys download a test this as well just to make sure please.
Postby Dragon Mech » Thu Apr 26, 2012 10:35 am
I'm sorry, I was unclear about the error messages that i got when trying to decompress the rom.
The error message for Winzip is:
Error in file #1: bad Zip file offset (Error local header signature not found): disk#1 offset: 0.
The error message for 7Zip is:
Unsupported compression method for 'Harvest Moon GBC 2 (U) [C][!].gbc'.
as i stated before, i have tried to decompress the rom with WInZip 8.0,10.0 and 7Zip 9.21 beta,9.25 alpha.
i hope that this information is helpful in some way.
Postby Hot Trout » Thu Apr 26, 2012 1:25 pm
The rom on the webserver must have become faulty. Can you test some others for me and I will look into uploading them again.
I live your avatar btw.
Postby te_lanus » Thu Apr 26, 2012 1:57 pm
HT: I also get the same error as he does on Harvest_Moon_GBC_2_(U)_[C][!].zip the other 2 Harvest Moon 2 roms is OK
Postby Dragon Mech » Thu Apr 26, 2012 2:31 pm
i downloded Harvest_Moon_GB_(U)_[C][!] and Harvest_Moon_GBC_3_(U)_[C][!] and they decompressed just fine.i'll try a few more and post how they did.
Postby JAHGoVeg » Thu Apr 26, 2012 3:16 pm
Same here. (:
Postby Hot Trout » Thu Apr 26, 2012 3:26 pm
Good work. I have now uploaded it again and it should work now. Please check it.
Postby Dragon Mech » Fri Apr 27, 2012 11:54 am
i downloaded the rom again and it worked perfectly! thanks HT :thankyou:
Postby JAHGoVeg » Fri Apr 27, 2012 2:07 pm
WooHoo!!! A satisfied customer! (:
Glad we could help, Dragon Mech. Never forget, we are always here to assist you... If you wanted to repay us you could stick around and be our friend... :(
Users browsing this forum: No registered users and 211 guests
