missing rom? (CPS 2)
Postby silent sniper » Sun Feb 12, 2012 5:38 pm
both in the pack and in the single roms section the file dingoo is not a rar or a 7z it's a .par file
silent sniper
Next LVL Up at : 150
Has thanked: 23 times
Been thanked: 61 times
Fav System: sony playstation
Re: missing rom? (CPS 2)
Postby owenrock » Sun Feb 12, 2012 9:58 pm
have you tried renaming the .par to .rar and trying it?
owenrock
Has thanked: 6 times
Been thanked: 11 times
Fav System: Nintendo
Postby silent sniper » Wed Feb 22, 2012 6:16 pm
owenrock wrote:have you tried renaming the .par to .rar and trying it?
no not yet need to give that a try.
silent sniper
Postby Kherr » Fri Feb 24, 2012 4:24 am
Hope you get it working because I've not even began to toy around with CPS 2 roms... lol.
Postby silent sniper » Sat Mar 17, 2012 6:59 pm
tried to open the .par file with both winrar and 7zip to no use,rename not helpful either.
either a left over file or a bad file type for the rom.
.par files are part of web archival tool for transmitting volumes over the web if i remember correctly.
silent sniper
Postby Hot Trout » Tue Mar 20, 2012 12:14 pm
Hi,
I just checked and that file should not even be there. It is not a CPS2 file and I am not sure why it is in that section. Please ignore it, I will also remove it later.
Sorry for the bum steer :problem:
Postby silent sniper » Wed Mar 21, 2012 7:21 pm
glad to help
i saw a device called dingoo or something alike that is basically can play old school roms so i thought it might be related.
silent sniper
Users browsing this forum: No registered users and 219 guests
