Will these ROMs work on The Wiz GP2X?
Postby GAMESHARQ » Wed Jun 02, 2010 11:13 pm
I am thinking of buying a Wiz GP2X handheld but before I do, I want to make sure I know where to get games that are compatible with it. Will these games work on the emulators made for the Wiz GP2X?
GAMESHARQ
Re: Will these ROMs work on The Wiz GP2X?
Postby Jesse » Thu Jun 03, 2010 1:59 am
Yes, they will work.
Well, it depends on the emulators. But generally yes. You only need to worry about incompatible ROM versions when you are using MAME, as far as I know.
Jesse
Postby GAMESHARQ » Wed Jun 09, 2010 1:01 am
Will the MAME roms listed here (http://www.theoldcomputer.com/roms/inde ... Mame-0.137) work on MAME4ALL?
GAMESHARQ
Postby Hot Trout » Wed Jun 09, 2010 9:25 am
The MAME set on this site is the complete set to date so yes the majority of the MAME roms should work.
Postby Jesse » Wed Jun 09, 2010 11:43 am
I believe the current version of Mame4All needs ROMs that are compatible with MAME 0.37b5. But I think some games in the newer versions of MAME (like 0.137) are still compatible enough with 0.37b5. I don't know. MAME confuses me.
If you need to, you can convert your ROMs from other MAME versions to 0.37b5 using this program, clrmamepro:
http://mamedev.emulab.it/clrmamepro/download.htm
The Mame4all package you downloaded should have the necessary .dat file for this process. It should also have a list of supported sets/games that you might want to look through before you try converting anything.
Honestly, that clrmamepro program confused the hell out of me, and so did it's documentation. Just put that .dat file in the corresponding folder, load the program, go to profiles, double click the .dat file, go to the rebuilder, set where you want the converted roms to go, then just drag and drop the roms on that window. I don't even know if I did it correctly. But most seem to work.
(BTW, I'm using the Dingoo-Linux port of Mame4all on my Dingoo A330 handheld.)
HotTrout : Your answer was better than mine :( :P
Jesse
Users browsing this forum: No registered users and 56 guests
