Anyone have a rom of WWF WrestleFest for MAME4ALL? (0.37b5)
Postby GAMESHARQ » Fri Dec 23, 2011 2:28 am
My all time favorite arcade game is WWF WrestleFest. Unfortunately, the emulator on my ipad is MAME4ALL and the only rom of WrestleFest available is for newer versions of MAME.
If anyone has a rom of WrestleFest that will work with MAME4ALL (0.37b5), please contact me or post here.
I also need a rom for WWF Superstars.
Thanks!
GAMESHARQ
Re: Anyone have a rom of WWF WrestleFest for MAME4ALL? (0.37
Postby Hot Trout » Fri Dec 23, 2011 1:57 pm
We have the full Mame 0.37b5 Roms set available for download available from the link. Check it out first.
Postby GAMESHARQ » Fri Dec 23, 2011 3:10 pm
I checked the list but I didn't see WrestleFest anywhere (unless you know something I don't). I was hoping that maybe someone here who is more experienced with this sort of thing was able to find a way to edit the new rom to work on the old emulator.
GAMESHARQ
Postby Hot Trout » Fri Dec 23, 2011 5:56 pm
The rom you are searching for is in the Mame 0.140 rom sets and onwards. It might not work with Mame4All.
Postby Tahbay » Sun Dec 25, 2011 4:28 am
I was just about to ask the same question!
I have tried several sites and any Wrestlefest or Superstars game I load does not work.
I loved those games.
Make sure to get Mat Mania.....Awesome!
Keep us posted if you find the ROMs.
Good luck and Merry X Mas
Tahbay
Postby laughing_lunatic » Mon Jan 02, 2012 7:12 am
Well, effectively, you can think of the MAME source as an operating system under which programs (the ROM's) run. To all intents and purposes you're looking for a program that requires as a minimum Win 7 (MAME 0.140+) that will also run on DOS 3.2 (MAME 0.37). A lot of the updates that occur are related to drivers, i.e. getting certain gfx and sound chips emulated accurately. This means that it's impossible to run certain ROM's on older MAME releases as the required code is literally non-existent in the MAME source.
GAMESHARQ wrote:I was hoping that maybe someone here who is more experienced with this sort of thing was able to find a way to edit the new rom to work on the old emulator.
If you can find a VERY talented MAME source programmer (like one of the MAME devs) that's willing to spend a LOT of time helping you out retrofitting 0.37, you may be on a winner, but that's highly, highly unlikely. It's MAME that would need to be programmed, the ROM is what it is. When they dump the ROM chips, the data stored on the ROM is taken. When work on the arcade system is updated and will now allow the ROM to run, it's then added to the ROM set as "working". It's not the other way around. They don't pull the data from the ROM chips and then think of a way to get the ROM to work.
laughing_lunatic
Has thanked: 8 times
Been thanked: 9 times
Users browsing this forum: No registered users and 222 guests
