Cannot download Mame4All roms?
Postby GAMESHARQ » Thu Dec 22, 2011 4:10 pm
I want to download some roms for mame4all, but no matter which game I choose, there is no "Download This Rom" link like there are with the regular MAME roms.
Are the mame4all roms no longer available here? If not, does anyone know where I can find some?
GAMESHARQ
Re: Cannot download Mame4All roms?
Postby gamfrkI » Thu Dec 22, 2011 7:36 pm
IMame4All Wiki wrote:It emulates arcade games supported by original MAME 0.37b5 plus some additional games from newer MAME versions.
Please use "clrmame.dat" file included in /var/mobile/Media/ROMs/iMAME4all to convert romsets from other MAME versions to the ones used by this version, using ClrMAME Pro utility, available in next webpage:
http://mamedev.emulab.it/clrmamepro/
Postby Hot Trout » Fri Dec 23, 2011 1:59 pm
To answer your actual question. To be able to download Mame4All roms you must log into the ROMs section. Just use your forum username and password and you will be able to download them.
Users browsing this forum: No registered users and 153 guests
