HOWTO | Extract .zip, .7z, or .rar files
Postby gamfrkI » Fri Oct 21, 2011 1:36 am
file ill be using
how to extract with winrar
right click and you should see something like this
click extract here (this will extract in the folder the file is located at)
this will start extracting the file
once its done you will have the files extracted
how to extract with 7zip
you should see this if you go over 7zip
Re: HOWTO | Extract .zip, .7z, or .rar files
Postby Kherr » Fri Oct 21, 2011 4:12 pm
You beat me to it... I was just wrapping up looking for work and was about to start this before I start working on another song... lol. :3 :hi:
Postby gamfrkI » Fri Oct 21, 2011 7:08 pm
i saw it in your other post and said ill do it :P i had nothing to do at that time
Users browsing this forum: No registered users and 54 guests
