Some CHD archives broken?
Postby yjmfan » Sun Oct 09, 2011 7:41 pm
I've had trouble extracting a few of the chd archives. For offrthnd.zip, outr2st.zip, and batlgr2.zip, I get extraction errors using Windows native unzipping and 7-zip. Have these been compressed using one of the weird new WinZip algorithms, or could the files really be broken? Thanks for any help.
yjmfan
Fav System: Arcade / SNES / PSX
Re: Some CHD archives broken?
Postby Hot Trout » Mon Oct 10, 2011 8:45 am
They were working but it is possible that they have become corrupt. I will not be able to check them for approx a week. If you do not hear anything back (because i forgot) please bump the topic again. I will get this fixed for you.
Postby yjmfan » Tue Oct 11, 2011 10:33 am
Thanks. I had a similar problem with the multi-part cliffhgr rar set (cobra worked fine). I'll update if I find any more apparently broken ones.
yjmfan
Postby yjmfan » Wed Oct 12, 2011 5:18 pm
It seems that about half of the CHD archives I'm testing are corrupted. Here is a list of the ones that do not extract correctly that I've found (there are likely more). Apologies if this ends up being user error, but I downloaded a few of these twice to be sure.
batlgr2
cliffhgr (multi-part)
gtrfrks
gundzaft
mach3 (multi-part)
offrthnd
ollie
outr2
outr2st
popn5
scg06nt
soulclb2
soulclb3
taiko9
taiko10
tekken4
zgundmdx
yjmfan
Postby yjmfan » Sat Oct 22, 2011 4:38 am
Bump :bump:
yjmfan
Postby Kherr » Sun Oct 23, 2011 12:24 am
Yea HT... :bump: :3
Postby Hot Trout » Mon Oct 24, 2011 9:42 am
Again sorry guys, been busy.
OK, I looked at the CHD's in question and also found that they were corrupt. I am going to maybe replace the CHD library with the latest version and fix it that way.
I will get to work on this and update you all soon, because the CHD's are over 200GB it will take some time so please be patient.
Postby Shando » Sat Feb 25, 2012 11:42 pm
Sorry to drag up an old-ish thread, but I've just downloaded the following CHDs and get corruption errors:
avalon20 (avalon13 & avalons both fine)
blitz2k (blitz & blitz99 both fine)
Unfortunately, I'm only on 1.5Mbps out here in the bush in sunny Queensland, so I don't want to risk downloading more only to find they are corrupted as well :(
If someone could check and let me know which CHDs are OK and which are corrupt that would be great.
Thanks for a great site, and keep up the good work.
Shando
Shando
Fav System: ZX 81 / Spectrum
Postby silent sniper » Sun Feb 26, 2012 5:20 pm
hey HT if you use win-rar and use the rar format you can add a recovery record up to ten percent which sometimes can help rebuild a corrupt archive,combine this with a self extracting archive and this can reduce errors to some degree.
silent sniper
Next LVL Up at : 150
Has thanked: 23 times
Been thanked: 61 times
Fav System: sony playstation
Postby Kherr » Sun Feb 26, 2012 5:22 pm
Yea, Win-RAR is the shit. :3
Users browsing this forum: No registered users and 175 guests
