Apple Pippin Roms Solved!!!!
Postby drbash » Thu Oct 06, 2011 6:22 pm
hello everyone,
finally after alot of trial and error(mostly error LOL)i figured out how to burn the pippin roms.
as follows: download the rom/extract with 7zip( after extraction is a bin.ecm file)/download ecm tools,then drop the file into the unecm application(once decoded the file is a bin file)/download bin2iso the convert the bin file into a iso/then burn to your cdr(i used cdrwin)
the games work on my pippin fine so far.if anyone has any questions,just leave a message. :thumbup:
drbash
Been thanked: 5 times
Fav System: Sega Dreamcast
Re: Apple Pippin Roms Solved!!!!
Postby Hot Trout » Sat Oct 08, 2011 9:02 am
Excellent work and many thanks for posting your solution. You have received thanks from me for this.
Postby SNK » Sat Nov 26, 2011 3:00 pm
Thanks man! I didn't try to burn PiPPiN roms yet, but everybody told me it's not easy but nobody could tell me how to do. So I will test it next days :)
SNK
Fav System: FM Towns
Postby gadgetali » Tue Jun 11, 2013 3:00 pm
I'm trying to burn games too, but I'm using a Macbook Pro using Toast and an app from app store called 'ECM'.
managed to follow the steps but when I put the CD into the Pippin it spits it back out again.
I used Toast on the 'copy' setting to copy the ISO to the CD?
Am I doing something wrong somewhere?
Thanks
gadgetali
Fav System: PS2
Users browsing this forum: No registered users and 112 guests
