Need help with controls
Postby freakybilly6971 » Sat Sep 03, 2011 3:45 am
Hello, I'm a total noob at this. I am running FCEUX as my emulator for nes roms. I don't have any other controllers other than mouse and keyboard. Trying to get it to work for Altered Beast. I am running this on XP Pro id that helps. I've been looking for hours to a solution. I appreciate any help you can give me, Thank you much!!!
freakybilly6971
Fav System: N64
Re: Need help with controls
Postby gamfrkI » Sat Sep 03, 2011 4:26 am
if your using fceux 2.1.5 to set the controls goto config then input and click configure set controls and done
Users browsing this forum: No registered users and 248 guests
