missing something with gameboy paks 1-3
Postby oneblackedout » Fri Jul 15, 2011 1:08 pm
I'm over looking something and need help to extract the 3 paks of gameboy colour ROMs. Do i change the end to something else or did i just get a bad download? Read the older post about bad files but it say it was fixed. Please help
oneblackedout
Fav System: NES
Re: missing something with gameboy paks 1-3
Postby BlueMaxima » Fri Jul 15, 2011 1:42 pm
You're going to need to clarify a little bit. What older post, and by "end", do you mean file extension, and what is the file extension now?
BlueMaxima
Been thanked: 36 times
Fav System: ZX Spectrum
Postby Hot Trout » Fri Jul 15, 2011 2:48 pm
It is not a bad download and you dont need to change the end or extension of the files. What you need to do is use 7zip program to unpack these archives. Search google for 7zip, download and install. This will sort the issue for you.
Postby oneblackedout » Fri Jul 15, 2011 3:17 pm
I've been use WinRAR and thought I extracted 7-zip files in the past but maybe not. Found new program with easy and worked great!!! Thank for the help and great downloads all around...!!!! THANK YOU!!!!
oneblackedout
Fav System: NES
Users browsing this forum: No registered users and 249 guests
