Unable to play Double Dragon on MAME
Postby GAMESHARQ » Tue May 17, 2011 11:23 pm
When I try to audit it, I get a whole bunch of messages that say NOT FOUND.
I'm not sure what the problem could be. I put the zip file in my roms folder just like all my other games but this is the only one that won't work. I also tried the rom from several different sites, but they all have the same problem.
Any ideas?
GAMESHARQ
Re: Unable to play Double Dragon on MAME
Postby te_lanus » Wed May 18, 2011 5:18 am
Could you tell us what is missing?
ddragon.zip
Try this one
(521.92 KiB) Downloaded 501 times
Postby GAMESHARQ » Wed May 18, 2011 11:02 am
When I try to audit the rom, I get this message:
ROM check: Failed
Sample check: None required
Details:
doubledr: sfix.sfx 131072 bytes NOT FOUND
CRC(354029fc) SHA1(4ae4bf23b4c2acff875775d4cbff5583893ce2a1)
doubledr: sp-s2.sp1 131072 bytes NOT FOUND
CRC(9036d879) SHA1(4f5ed7105b7128794654ce82b51723e16e389543)
doubledr: sp-s.sp1 131072 bytes NOT FOUND
CRC(c7f2fa45) SHA1(09576ff20b4d6b365e78e6a5698ea450262697cd)
doubledr: usa_2slt.bin 131072 bytes NOT FOUND
CRC(e72943de) SHA1(5c6bba07d2ec8ac95776aa3511109f5e1e2e92eb)
doubledr: sp-e.sp1 131072 bytes NOT FOUND
CRC(2723a5b5) SHA1(5dbff7531cf04886cde3ef022fb5ca687573dcb8)
doubledr: asia-s3.rom 131072 bytes NOT FOUND
CRC(91b64be3) SHA1(720a3e20d26818632aedf2c2fd16c54f213543e1)
doubledr: vs-bios.rom 131072 bytes NOT FOUND
CRC(f0e8f27d) SHA1(ecf01eda815909f1facec62abf3594eaa8d11075)
doubledr: sp-j2.rom 131072 bytes NOT FOUND
CRC(acede59c) SHA1(b6f97acd282fd7e94d9426078a90f059b5e9dd91)
doubledr: sm1.sm1 131072 bytes NOT FOUND
CRC(97cf998b) SHA1(977387a7c76ef9b21d0b01fa69830e949a9a9626)
doubledr: 000-lo.lo 65536 bytes NOT FOUND
CRC(e09e253c) SHA1(2b1c719531dac9bb503f22644e6e4236b91e7cfc)
When I try to load the rom, I get this message:
sfix.sfx NOT FOUND
sp-s2.sp1 NOT FOUND
sm1.sm1 NOT FOUND
000-lo.lo NOT FOUND
ERROR: required files are missing, the game cannot be run.
GAMESHARQ
Postby te_lanus » Wed May 18, 2011 11:33 am
That is the Neo-geo bios that's missing.
Those missing I've attached
neogeo.zip
(66.03 KiB) Downloaded 929 times
Postby GAMESHARQ » Wed May 18, 2011 5:00 pm
Where do I put these files?
Also, should I be using MAME or a Neo-Geo emulator to play this?
GAMESHARQ
Postby te_lanus » Wed May 18, 2011 7:07 pm
The file should go into the Romz directory.
But use this one: http://www.theoldcomputer.com/roms/getf ... 9nZW8uemlw
Re: Why?? Unable to play Samurai Shodown 3 on MAME0.137
Postby areelovemame » Wed Jul 13, 2011 6:48 am
Dear, God of Game
When I try to audit it, I get a whole bunch of messages that say NOT FOUND, although I've download roms for Mame0.137 in this site.
Please, HELP..Me n my Bro are Samurai Shodown Lovers.
areelovemame
Fav System: MAME
Postby stinow » Wed Oct 19, 2011 9:25 pm
areelovemame wrote:Dear, God of Game
Sorry for the :bump: ... but I'm experiencing the exact same problems.
The error in MAME is:
"The selected game is missing or one or more required ROM or CHD images."
I also have the games downloaded, all still in the .zip files. There are multiple .bin files in the .zip's, but no .cue file or something.
Can anyone help me out with this also? I'd be glad to get the NeoGeo games working! :freakout:
Postby royle.christopher » Sun Nov 27, 2011 4:33 am
Log says that these files are missing:
21a-1-5.26 NOT FOUND
21a-3.24 NOT FOUND
21a-4.23 NOT FOUND
I have the same problem with PacMan which should have all the files.
it seams that the files are not in the download.
royle.christopher
Fav System: Macintosh
