Error: The file ... does not exist
Postby stoniey420 » Fri Mar 25, 2011 3:30 pm
This error happens with all the Sharp X68000 Games.
Also, the filenames have "%20" instead of spaces...
stoniey420
Re: Error: The file ... does not exist
Postby Hot Trout » Fri Mar 25, 2011 4:36 pm
Firstly welcome and thank you for bringing this to my attention.
I have just investigated the Sharp X68000 section and you are correct. All of the folders in the GAMES section of the X86000 section are not working, except for thr 0-9 folder which does appear to be working.
To fix this issue I will need to upload all of those folders again. I will start this asap but it will take some time as there is over 1.5GB of files.
Please keep checking back to see when they will be ready. I will update this post when it is finished.
Thank you :hi:
Postby Hot Trout » Fri Mar 25, 2011 6:05 pm
Update :
We are currently at folder K and moving fast. All of these roms should be replaced within the next four hours from now. You can check it out then and report back.
Postby Kherr » Fri Mar 25, 2011 8:01 pm
Nice way to respond to the users HT. Someone who values his guests. :3
Postby Guest » Fri Mar 25, 2011 10:48 pm
It cause were a super great community here
Postby Hot Trout » Sat Mar 26, 2011 9:36 pm
I know if I was trying to download a particular rom and it was the only one that did not work I would also be annoyed. So I quickly uploaded the entire thing.
You guys are always quick to answer questions when people ask them, so I guess I need to keep my end of the bargin as well.
Users browsing this forum: No registered users and 260 guests
