update?
update?
Postby gamfrkI » Tue Sep 28, 2010 11:39 pm
Re: update?
Postby Hot Trout » Tue Sep 28, 2010 11:43 pm
Good question. AT the minute I am concentrating on roms and emulators and will continue to until probably after xmas.
The blog I might replace with a BLOG type forum in here instead. The libararys are being replaced as I go, already the new box scans section and soon to come the manuals and magazines sections.
The museum I may never do, mostly because there are already superb dedicated websites out there like www.old-computers.com.
Hope this helps answer some questions. If you want to take on a section, blog etc let me know.
Re: update?
Postby gamfrkI » Tue Sep 28, 2010 11:45 pm
ok :D
ill let you know if do 1 of these
Re: update?
Postby Kherr » Wed Sep 29, 2010 9:38 pm
Oh, and trout, I think you need to change the links on some of the rom database so they're easier to click. It's almost impossible to click the "i" or "l" when picking a catagory that is organized via letter. It's great that it's organized like that, but yesterday when I was DL'ing a lot of the GBA library for my Dingoo, I had a hard time clicking on the "i" and the "l" sections of the database. Just thinking that instead of using lowercase lettering, you should be using a capital system for single letter organization... IDK if I've explained it thoroughly enough, but I think you should have the idea. :3
