May i suggest an emulator to put up if its possible to get it. It's called "PSXfin"
Its hard to find but i found this emulator to be one of the easiest psx emulators to deal with. The emulator itself is already packaged with all the "inputs" that are needed within the .exe file. All self contained.
wait i found a link in a forum post.
http://forums.techarena.in/windows-software/1247486.htm
usually a "d3dx9_26.dll" error will show up if you don't have that file already on your computer when you try to run the emulator but you are able to donwload the file that is needed from this link
http://www.dll-files.com/pop.php?dll=d3dx9_26
Just put the dll file in with the same folder as "psxfin.exe" and it should start up. Only thing left is a BIOS file but almost all psx emulators need those.
~ All files and links have been virus/spyware scanned with paid versions of virus/spyware/malware programs.
