Aggression
Aggression
Postby crustyasp46 » Fri Oct 25, 2013 3:56 pm
A little program, to kill time, vent frustration, that I like. Works on my Win7 machine.
Beat your Desktop! It deserves it!
Use this little tool to get rid of your computer related aggression. Use a baseball bat, a laser sword, a blaster and even Ms. Pacman for your revange...
This program started as a test on how to get a screenshot of the current windows screen.Once I had that, I played around with the BITMAP - and this is the final result.
Running the program
Just double-click on aggression.exe. Choose the tool of your choice via mouse. Once you have selected a tool, you can also use 1,2,3 and 4 to switch between them. Pressing ESC in the menu will quit the program. Pressing ESC while a tool is active, the menu will be displayed.
Aggression comes with full source. It's meant to be compiled against the static library of allegro. If you want to compile it against the DLL version, you have to remove #define ALLEGRO_STATICLINK line at the top of the .c file.
Downloads
It's OK for me if you place these downloads on your site, as long as you're giving correct credit and link back to
http://www.steinke.net/
aggression.zip
(534.86 KiB) Downloaded 330 times
: Aggression (including source)
Please note that we have tested all downloads to ensure that they work the way they are supposed to work.But, since I don't have the time and/or equipment to take all contingencies into account,
THIS SOFTWARE IS PROVIDED TO YOU "AS IS" WITHOUT REPRESENTATION, WARRANTY OR CONDITION OF ANY KIND, EITHER EXPRESS, IMPLIED, OR STATUTORY INCLUDING, BUT NOT LIMITED TO, IMPLIED REPRESENTATIONS, WARRANTIES OR CONDITIONS OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, DURABILITY, TITLE, NON-INFRINGEMENT OF INTELLECTUAL PROPERTY RIGHTS OR INTER-OPERABILITY OF PRODUCTS OR SERVICES.USE AT YOUR OWN RISK.
Users browsing this forum: No registered users and 63 guests
