Problems after changing password
Postby ProbablyMike » Wed Apr 16, 2014 10:33 pm
Hi,
I've just changed my password on the forums, but now cannot login to the roms section on the main site.
I've logged out of the forum, cleared cookies etc, tried a different browser.
I can log back into the forum (I'm posting this!) but whenever I try to login the main site I get "Wrong username/password"
I've type my password into Notepad, and copied & pasted it to login to the forums which works, but then does not work when pasted to the main site.
Please help!
Cheers,
Mike
ProbablyMike
Fav System: ZX Spectrum
Re: Problems after changing password
Postby Hot Trout » Thu Apr 17, 2014 9:52 am
Hi,
Try changing your password again but this time don't use too many symbols. Try and use # or @, don't use " or ' and use CAPS as well as numbers.
Sometimes certain symbols don't translate properly in the site code.
I hope this helps.
Postby ProbablyMike » Thu Apr 17, 2014 9:16 pm
Cheers, changed it again, not using so many symbols this time and it's working good.
Many thanks,
Mike
ProbablyMike
Users browsing this forum: No registered users and 108 guests
