Problem with downloads.
Postby tabouzar » Sat Mar 30, 2013 8:25 pm
hey there....just became a paid member....love the site....but now since im a member, when i go to download anything....the "Click to Download" link isnt working....i click on it many times and i dont get a pop up window anymore...any one know a solution?
Thanks!
tabouzar
Re: Problem with downloads.
Postby Kherr » Sat Mar 30, 2013 8:46 pm
Do you have any popup blockers installed? That's about the only thing I can think of...
Postby tabouzar » Sat Mar 30, 2013 9:05 pm
well i dont...i was able to DL before i just became a member....it was after i became a member.
tabouzar
Postby tabouzar » Sat Mar 30, 2013 9:11 pm
ok weird....i can download the emulators...but i cannot DL roms.....no window pop ups...then...it does if i DL an emulator.
tabouzar
Postby tabouzar » Sat Mar 30, 2013 9:49 pm
lame
tabouzar
Postby crustyasp46 » Sun Mar 31, 2013 12:47 am
Try logging off and log backin on the roms page. If that fails try a different browser. That is all I am able to suggest for now, as I really have little knowledge on the roms section. Otherwise hopefully somone else will pop in with a suggestion.
Postby Kherr » Sun Mar 31, 2013 1:17 am
Also you could try different browsers such as Google Chrome or Mozilla Firefox. I can download just fine from both of those browsers (In case you aren't already using one of them...)
Also try what Crusty said, because that could be the issue also. Other than that I have nothing else in terms of suggestions... I'm sorry.
Hot Trout, can you think of anything?
Postby tabouzar » Sun Mar 31, 2013 4:04 am
yes...ty...i tried another browser and it worked....something must of tweaked out my firefox....i used IE for the DL....sweet!
tabouzar
Postby PMJPlay » Sun Mar 31, 2013 4:18 am
I used Chrome primarily but I used IE to download roms off the site.
Try cleaning your cache and password saves in Firefox? Maybe that will help....
Postby Kherr » Mon Apr 01, 2013 1:04 am
tabouzar wrote:yes...ty...i tried another browser and it worked....something must of tweaked out my firefox....i used IE for the DL....sweet!
Glad it worked out for you! :freakout:
Enjoy the site man, it only gets better from here. :hi:
