wat is this
wat is this
Postby gamfrkI » Tue Aug 24, 2010 1:07 am
wat is the local gallery
Re: wat is this
Postby Guest » Tue Aug 24, 2010 4:50 am
Where are you seeing this?
Re: wat is this
Postby gamfrkI » Tue Aug 24, 2010 5:53 am
open user control panel
profile
edit avatar
display gallery
Re: wat is this
Postby Guest » Tue Aug 24, 2010 6:06 am
My best guess is that the phpBB code allows multiple avatar pics to be saved and thus there would be a gallery.
That would allow you to upload say 3 different avatars and then when you feel like it, just display the gallery and choose the new one you want to use.
It seems though that we are limited to only 1 avatar and so thats all thats displayed in the gallery. Is the one we are currently using.
So we have the capability of more avatars but we are limited to only one. Yes? :thumbup:
Users browsing this forum: No registered users and 24 guests
