Unlimited Upgrade not activated
Postby zer0-G » Fri Aug 20, 2010 3:46 am
Hey there, in need of some help here. I registered and donated, but it seems the "instant" upgrade has not yet taken affect. Any thoughts?
zer0-G
Re: Unlimited Upgrade not activated
Postby Guest » Fri Aug 20, 2010 5:03 am
This is a problem that Hot Trout will have to help you with seeing as he is the forum host. Ill let him know and he will get back wit you shortly. =]
Postby Hot Trout » Fri Aug 20, 2010 10:38 am
Hi,
I noticed that your profile has changed to SUPPORTER which means that you should be ok. Did you remember to Login when in the roms section. Failing this please send me the email address you used to setup your account. USE a PM DO NOT POST YOUR EMAIL ADDRESS HERE.
I will then check this out for you immediatly.
UPDATE : I have checked the SQL and there was an error, not sure why but I have fixed this and all should be well again. Let me know how you get on.
:thankyou:
Postby zer0-G » Sat Aug 21, 2010 9:32 pm
I just logged in a bit ago, and it seems to have taken effect. For whatever reason it just didn't happen right away. No harm, no foul. Thanks for your promptness!
Chris
revision:
Saw that you posted an update about fixing some issue. I missed it the first read through. Thanks for that!
zer0-G
Postby Hot Trout » Sun Aug 22, 2010 10:19 am
You are welcome. Maybe in a few years when this thing is as big as Amazon or say heck ... Google. Then I will be able to completly ignore your crys for help and just watch the money pour in. :wtf: :wtf:
Until then we will continue to be a careing, helpful and supportive website. :thumbup:
Users browsing this forum: No registered users and 24 guests
