Problem with single download packs - SOLVED
Postby baker2967 » Mon Aug 08, 2011 2:47 am
I can't open the USA SNES mega packs. Is there a certain way of opening beside 7-zip.
baker2967
Re: Problem with single download packs
Postby BlueMaxima » Mon Aug 08, 2011 2:57 am
Try WinRAR?
BlueMaxima
Been thanked: 36 times
Fav System: ZX Spectrum
Postby Hot Trout » Mon Aug 08, 2011 9:48 am
Hi,
for all 7-zip files you will need to download and use 7-zip.
Postby baker2967 » Tue Aug 23, 2011 3:17 am
I did but still won't open. It says "The archive is either in unknown format or damaged"
baker2967
Postby Hot Trout » Tue Aug 23, 2011 5:35 pm
Hi,
Have you downloaded all the parts of the archive? Always check Mega Packs because sometimes thet span more than one file (due to size restrictions). For example, if it says
SNES Mega Rom Pack Part 1
SNES Mega Rom Pack Part 2
SNES Mega Rom Pack Part 3
You will need to download all three before trying to unpack them using 7zip. I hope this helps. If not let me know and I will check the files.
Postby baker2967 » Wed Sep 07, 2011 2:07 am
Thanks, that worked this time when I opened them at the same time.
baker2967
Postby Hot Trout » Wed Sep 07, 2011 10:20 am
Thats good and thanks for letting us know. :D
Users browsing this forum: No registered users and 112 guests
