Help: Burning Dvds
Re: Help: Burning Dvds
Postby Hot Trout » Tue Apr 19, 2011 3:13 pm
This is off topic. Moderator, please move this post to the support forums and continue on from there :)
Postby Guest » Wed Apr 20, 2011 2:16 am
MOD: Topic Moved. Please post in correct forums
- Guest -
And to answer your question:
By copy/burning DVDs I assume you mean burning movies? Yes?
If thats the case you would place the DVD in your DVD drive and then use software to rip the DVD and put it on your computers hard drive. After that has completed, you take out the DVD and place in a blank DVD that you wish to burn the movie to. Use (probably the same software) to burn the file you have on your hard drive to the DVD in the drive. Will take a while but when its finished you have suscessfully made a copy of your DVD.
Let us know if you need some more help
Postby stinow » Wed Jan 18, 2012 10:30 am
This is really a :bump: , because maybe some other people might find this a useful topique! :P
I advice to use a free tool like 'CDBurnerXP'.
* Fire it up
* Click 'Copy or grab disc'
* Select the source CD- or DVD-rom drive
* Check 'Hard disc' at nearly the bottom of the wizard
* Hit in a filename
* Burn the baby! :roll:
:wink2:
