Controller suggestion for Phablet
Postby cheezed » Thu Nov 06, 2014 1:07 am
First time posting, so easy with the flaming guys LOL. I just loaded mame_37b5 on my Galaxy tab4 7 and Galaxy note4, tested both with a few roms and works perfect, but the virtual controller buttons are horrible, so I would like a few suggestions in what controllers are being used now with OS 4.4.2/4.4.4 and Mame_37b5. I came across Ipega pg9025/pg9023, your thoughts?
cheezed
Fav System: xbox360
Re: Controller suggestion for Phablet
Postby PMJPlay » Fri Nov 07, 2014 1:10 pm
I used a PS3 Controller and the Sixaxis app for my gaming needs. If you have a recent Xperia device you get PS3 Controller native compatibility.
Postby cheezed » Fri Nov 07, 2014 6:12 pm
Alzabo, thanks for info. I'm a xbox man, so no ps3 controller. Maybe there's an xbox pairing app like sixaxis. Maybe someone can chime in, but I will do a little research myself.
cheezed
Fav System: xbox360
Postby PMJPlay » Sun Nov 09, 2014 12:05 am
I don't even own a PS3 cause I just bought the controller just use on my tablet :D
Postby cheezed » Mon Nov 10, 2014 6:38 pm
Just received logitech tablet joystick, works alright. I just ordered iped pg-9025 joystick. I will post a review when I receive it.
cheezed
Fav System: xbox360
Postby cheezed » Fri Nov 21, 2014 8:36 pm
Ipega controller is awesome, works perfect. Using it with my galaxy tab 4 and note 4 and when I mirror it to samsung smart tv its pretty dam cool. Programing the buttons to mame build 37b5 was easy, the only issue I have its a bit small for hands but then again its compact for traveling.
cheezed
Fav System: xbox360
Users browsing this forum: No registered users and 34 guests
