Samsung galaxy young s5360 android phone
Postby ukguy183 » Thu May 31, 2012 1:24 pm
my samsung galaxy young s5360 android phone is slow and when im talking to people on the phone it cuts off. What can i do to fix these problems?
ukguy183
Re: Samsung galaxy young s5360 android phone
Postby johnmecay » Mon Dec 24, 2012 2:10 pm
You can change your battery and install antivirus because cause of virus it will be happen.
johnmecay
Fav System: dell
Postby Kherr » Sat Dec 29, 2012 6:51 am
I would suggest getting AVG Anti-Virus from AVG Mobilation. I would also suggest performing a hard-reset on your phone (returning to factory settings) as sometimes when you upgrade the OS to newer versions it causes issues with the phone on a whole. I would fully suggest using ODIN and flashing a fresh brand new ROM onto the device as that usually fixes almost EVERY single issue with the device in question. I did it with my Samsung Galaxy S2 Epic 4G Touch and it fixed all my issues after upgrading from Gingerbread to Ice Cream Sandwhich.
I would also try going into your phones recovery ROM (google how to do it with your device) and clearing your cache. That can also fix many issues caused by devices.
Last but not least I would suggest getting an app called Juice Defender as that helps to preserve battery life and also seems to stabilize the phone's operation. I don't know why but my phone always runs better when I have Juice Defender installed.
Hopefully some of this helps you out. :hi:
Postby jagisteve » Wed Apr 17, 2013 12:21 pm
I have spent hours setting up on my android phone and NOW you tell me it is not working with my phone. Why is the app still on the google play site?
jagisteve
Postby Hot Trout » Wed Apr 17, 2013 2:22 pm
Other than Kherr, none of these posters are making any sense. You look like spammers so before I delete your accounts could you post something intelligent into this thread.
Users browsing this forum: No registered users and 17 guests
