Droid X receives Gingerbread!
Postby Guest » Mon Mar 28, 2011 5:46 am
Download and Install Instructions
Installing Firmware
1. Download Gingerbread release file from the TBH app or one of the mirrors below
2. Use Bootstrap to get your phone into recovery.
3. Create a backup (This is not compatible with new firmware)
4. Install the Firmware using recovery
- select install zip from sdcard
- choose zip from sdcard
- navigate to teamblackhat folder
- select the file you downloaded
5. Restart phone
If your phone bootloops you need to enter recovery and wipe data:
1. hold down power and home.
2. when you see the triangle hold down both volume buttons
3. select wipe data/factory reset ---press power button to select
4, reboot system
Download Mirrors:
http://www.megaupload.com/?d=2NWM5PYP
http://www.multiupload.com/RS_34Q1IPM9B2
http://www.multiupload.com/MU_34Q1IPM9B2
http://www.multiupload.com/DF_34Q1IPM9B2
http://www.multiupload.com/HF_34Q1IPM9B2
http://www.multiupload.com/ZS_34Q1IPM9B2
http://www.multiupload.com/UP_34Q1IPM9B2
MD5 Sum - bccdcb1b3436c72c311f2df3077dcb10
Users browsing this forum: No registered users and 65 guests
