PC Help
PC Help
Postby gamfrkI » Wed Jan 19, 2011 8:36 am
when i connect my usbs (3)[sony 16gb,kingston 1gb,and hp(?) 2gb] they shut down my comp but only 1[duracell 8gb] of them doesnt how do fix this
Re: PC Help
Postby Hot Trout » Wed Jan 19, 2011 10:13 am
Is this a laptop or desktop?
Are you using an additional USB hub?
It is most likely a power issue with your USB
Re: PC Help
Postby gamfrkI » Wed Jan 19, 2011 11:29 am
Hot Trout wrote:Is this a laptop or desktop?
its a desktop
and no additional usb hub
everything was fine like 3 - 4 days ago idk why it would start now
Re: PC Help
Postby Hot Trout » Wed Jan 19, 2011 11:36 am
The drain on power on the usb could have caused it to seperate the solider on the MB causing a dry joint ans this is making a short and causing the crash/off.
USB pen drives/hdd should not be left attached if possible.
Re: PC Help
Postby gamfrkI » Sun Jan 23, 2011 5:40 am
Hot Trout wrote:The drain on power on the usb could have caused it to seperate the solider on the MB causing a dry joint ans this is making a short and causing the crash/off.
so something in my usb hub or my usbs are causing my computer to crash right?
edit:
i added 1 gb (1024 mb) ram and it makes my computer not start either my computer supports up to 2 gb ram
also a mouse (not usb) also make my computer not start it loops at the win xp loading screen
Re: PC Help
Postby Kherr » Tue Jan 25, 2011 1:54 pm
Almost sounds like your computer is failing post, or the PSU is simply going. Same exact thing happened to my old gaming rig before the motherboard went. I think the PSU was failing, and in turn that harmed the motherboard. It only fails post now. *sad face*
Re: PC Help
Postby gamfrkI » Tue Jan 25, 2011 8:30 pm
so eventually it will just die
it should of happend years ago :/ (8 year old computer with all the same parts when i bought it)
Re: PC Help
Postby Kherr » Tue Jan 25, 2011 11:23 pm
Yea, my computer when it died was 7 years old.
Re: PC Help
Postby gamfrkI » Tue Jan 25, 2011 11:28 pm
looks like i need a new computer :C
