Keyboard Dancing LED Light Trick
Postby crustyasp46 » Tue Nov 05, 2013 2:20 pm
Keyboard led trick
As we know keyboards having 3 LEDs
1. NUM LOCK
2.CAPS LOCK
3.SCROLL LOCK
Here is a trick to use the lights of your keyboard in a more creative manner in Windows.
This trick uses a simple Visual basic script which when
activated makes your scroll lock, caps lock and num locks LED’s flash in a cool rhythmic way which gives the perception of a live disco on your keyboard.
MAKE THE DISCO WITH 3 SIMPLE STEPS :
Open Notepad Paste The below Code
Set WEBCHILLER =wscript.CreateObject(“WScript.Shell”)
do
wscript.sleep 100
WEBCHILLER.sendkeys “{CAPSLOCK}”
WEBCHILLER.sendkeys “{NUMLOCK}”
WEBCHILLER.sendkeys “{SCROLLLOCK}”
loop
Then save this file as led.vbs (.vbs is must)
Open your save file and see your keyboard led blinking like disco lights.
How to disable blinking Led ?
1. First open Task Manager [ctrl+alt+del ]
2. Then Go to process tab.
3. Select wscript.exe
4. Click on End process.
Source :
http://incredibleengineering.com/keyboard-dancing-led-light-trick
Re: Keyboard Dancing LED Light Trick
Postby Kherr » Thu Nov 07, 2013 12:09 pm
Doesn't seem to work on Windows 8 Pro or Windows 7 Pro. T_T
Postby Dragon Mech » Wed Nov 20, 2013 7:17 pm
i've been playing with this a little bit and here a a couple more scripts:
Set WEBCHILLER =wscript.CreateObject("WScript.Shell")
do
wscript.sleep 80
WEBCHILLER.sendkeys "{NUMLOCK}"
wscript.sleep 80
WEBCHILLER.sendkeys "{CAPSLOCK}"
wscript.sleep 80
WEBCHILLER.sendkeys "{SCROLLLOCK}"
loop
do
wscript.sleep 10
wscript.sleep 100
wscript.sleep 100
wscript.sleep 100
wscript.sleep 100
wscript.sleep 100
wscript.sleep 10
wscript.sleep 100
wscript.sleep 100
wscript.sleep 100
wscript.sleep 100
wscript.sleep 100
loop
in order for these scripts to work properly, please make sure you have your Num Lock, Caps Lock, and Scroll Lock turned off before you use them. or else they won't look like they'er supposed to. have fun :)
