Pentium 133MHz question
Postby VoltureX » Thu Oct 24, 2013 10:52 pm
Hi.
I have an Intel M507 mainboard which states in the manual I can only use up to 8.4GB harddrives. Are there any hacks so I can use my 40GB harddrive instead?
Thanks!
Volt.
VoltureX
Fav System: Amiga 1200
Re: Pentium 133MHz question
Postby Kherr » Tue Nov 05, 2013 10:48 am
I'm not sure about that, we'll have to look into this. I'm assuming you've not found anything on google?
Postby PMJPlay » Tue Nov 05, 2013 12:15 pm
Welcome to the Forums btw!
Postby SE7EN » Tue Nov 05, 2013 2:59 pm
You MIGHT be able to use a different computer to format that drive to have multiple partitions that are smaller than the limit.
Postby lotharian » Fri Nov 29, 2013 7:23 am
I am pretty sure thats the board that I used at work back in the day... and there was a flash upgrade that got it to see larger drives, I think 20 gb or so and it was wonky and only worked with the old Maxtor Big Foot drive. The tech back then was unforgiving with flashes so be warned.
lotharian
Next LVL Up at : 25
Next LVL Up at : 25
Has thanked: 10 times
Been thanked: 41 times
Fav System: Saturn
Postby Roman78 » Thu Feb 13, 2014 7:36 am
There are some limitations whit hard drives at 8,4gb, 32gb and 128gb. Depending on the disk there are jumpers to set it to the 8,4 or 32gb limitation (for your mainboard it should set to 8,4). And than there is a software tool from the manufacturer (when you cant find it i think i have all here) to enable a softbios kind thing in the MBR of the disk to enable the whole disk space.
Roman78
Been thanked: 37 times
