CPU Temperature
CPU Temperature
Postby GozmitJosh » Fri Oct 01, 2010 12:17 am
hmm....i wonder if it is healthy for my cpu to be running at ~90 degrees Celsius (~200 degrees Fahrenheit) :lol:
GozmitJosh
Next LVL Up at : 170
Has thanked: 20 times
Been thanked: 26 times
Fav System: Playstation 1
Re: CPU Temperature
Postby crustyasp46 » Fri Oct 01, 2010 4:02 am
Should keep your Buds cool :roll: :lol:
Re: CPU Temperature
Postby Kherr » Fri Oct 01, 2010 5:38 am
hmm... you could make some s'mores with it...
No, I don't think it's good for it to be running at ~200 Degrees Fahrenheit. :3
Re: CPU Temperature
Postby Hot Trout » Fri Oct 01, 2010 10:05 am
That is just a little too hot for any CPU. :wtf:
What is the CPU/Board and why is it so hot. You are luck not to have a fire.
Re: CPU Temperature
Postby GozmitJosh » Fri Oct 01, 2010 4:57 pm
its a laptop O.O
and its been running this hot since i bought it 7 months ago. Never had an issue with it shutting down nor has it really had any issues at all.
Intel Core i3 330M @ 2.13GHz 100 °C
Arrandale 32nm Technology
Cores 2
Threads 4
Name Intel Core i3 330M
Code Name Arrandale
Package Socket 1156 LGA
Technology 32nm
Specification Intel(R) Core(TM) i3 CPU M 330 @ 2.13GHz
Family 6
Extended Family 6
Model 5
Extended Model 25
Stepping 2
Revision C2
Instructions MMX, SSE, SSE2, SSE3, SSSE3, SSE4.1, SSE4.2, EM64T
Bus Speed 133.0 MHz
Rated Bus Speed 2394.8 MHz
Stock Core Speed 2133 MHz
Stock Bus Speed 133 MHz
Average Temperature 100 °C
Manufacturer Hewlett-Packard
Model 3658
Version 049B210002241210000020000
Chipset Vendor Intel
Chipset Model Havendale/Clarkdale Host Bridge
Chipset Revision 02
Southbridge Vendor Intel
Southbridge Model HM55
Southbridge Revision 05
BIOS
Brand Hewlett-Packard
Version F.15
Date 01/05/2010
Always runs smooth and snappy even on extremely high graphics games after hours of play.
EDIT: I wonder how hot it gets if i overclock it :lol: could it even withstand the temperatures to even be over clocked without adding a cooling system....if its even possible with a laptop.
GozmitJosh
Re: CPU Temperature
Postby Hot Trout » Fri Oct 01, 2010 5:42 pm
Intel Processors
The maximum temperature of an Intel processor depends on the model but it normally range from 60-65 ° C for the Pentium 4, 50-65 ° for the Core models and 70 ° C for the Nehalem generation (i3/i5/i7 ). The mobile processors support up to 100 ° C approximately.
•You can have all the necessary information on Intel site:
•http://ark.intel.com/Default.aspx
•For example, the optimal temperature is 62 ° C for the Q6600:
•http://ark.intel.com/Product.aspx?id=29765&processor=Q6600&spec-codes=SL9UM,SLACR
•and 72 °C for the Core i5 750:
•Beyond this value, a thermal protection of the system intervenes and brings the processor to its lowest frequency, blocking the CPU ratio to a minimum.
•If the temperature rises again, the CPU automatically shuts off, no thermal destruction is virtually impossible latest processors.
AMD processors
The maximum operating temperature of an AMD processor is determined by the trade reference (OPN) of this processor. The OPN is on top of the processor. Example:
•A X1800 D M S 3 C
This temperature is indicated by the third character from the right of the OPN. This character can take the values S, T or V.
These characters identify the maximum temperature of use of the AMD Athlon (TM) XP: V = 85 º C, T = 90 º C, S = 95 º C.
For the AMD Athlon 64, Athlon 64 X2 (all sockets and all frequencies) and Phenom, it is generally accepted that 60 ° represents the upper limit.
http://products.amd.com/en-us/DesktopCPUResult.aspx
Re: CPU Temperature
Postby JAHGoVeg » Fri Oct 01, 2010 9:59 pm
wait i thought -200 F was cold?
Re: CPU Temperature
Postby crustyasp46 » Fri Oct 01, 2010 10:03 pm
JAHGoVeg wrote:wait i thought -200 F was cold?
It is, that is why I said it should keep his Bud cool, Hot beer isn't to my liking! :lol: :cheers:
Re: CPU Temperature
Postby Kherr » Sat Oct 02, 2010 11:46 am
He didn't use the dash "-", he used this thingy: ~
The squiggly means "around." :3
Hold shift and press the key directly under the escape key. XD
~ = around. :ugeek:
Re: CPU Temperature
Postby JAHGoVeg » Sun Oct 03, 2010 3:12 am
~ = around. :ugeek:
Gosh i know what ~means! lol :lol: . sorry, I feel stupid now. lol
~200 degrees is way to freakin hot! and i agree with Kherr make some smores! :D
Users browsing this forum: No registered users and 164 guests
