PS/2 or USB solution for Win 98 PC
Postby stinow » Thu Sep 13, 2012 8:41 am
Hi there,
Does anyone know of a good (and tested) solution to get a "modern" PS/2 or USB keyboard and mouse to work on my:
P1 166 with Windows 98?
I'm thinking about an USB PCI card or something, but will that be compatible with Win 98 and with most old games?
Thanks for the info!
:cheers:
Re: PS/2 or USB solution for Win 98 PC
Postby Hot Trout » Thu Sep 13, 2012 9:44 am
You should be able to get a PCI 1.1 spec card that will work inside a windows 98 computer, just about.
Postby stinow » Fri Sep 14, 2012 1:24 pm
Hot Trout wrote:You should be able to get a PCI 1.1 spec card that will work inside a windows 98 computer, just about.
Darn, found one! For €2,50 hehehe. And W'98 is supported.
Will get my old PC-in-a-beer-case(mod) from upstairs again.
Was my first casemod ever, it's from the P1 166mhz days, so you can say one of the earlier casemods around I think :eh: .
