Play Hundreds of Free Games on Ubuntu
Postby crustyasp46 » Tue Nov 01, 2011 9:54 pm
Saturday, October 29
'Mega Games Pack' Lets You Install and Play Hundreds of Free Games on Ubuntu
by Nitesh
Mega Games PAck for Linux.png (103.47 KiB) Viewed 3943 times
Mega Games Pack (MGP) by GlennLChugg is a standalone client for Ubuntu that allows you to download and play hundreds of free Linux games. Though there is Ubuntu Software Center (USC) and Desura client, MGP have some other useful features.
All games are free to install and play. MGP can launch any installed game from client itself.
Automatically adds your locally installed games to the client by searching .desktop files.
Uses GetDeb and other online repositories to update games.
Automatically fetches description and screenshots. You can also edit screenshots and description to add your own versions.
All games are neatly categorized into meaningful categories.
MGP is currently in beta testing mode so there will be bugs and issues. Also only one developer is working on it at the moment so keep that in mind. Some of the planned features include a themeable interface and support for global hotkeys.
Some Screenshots
Mega Games Pack for Linux 1.png (116.21 KiB) Viewed 3943 times
Mega Games Pack for Linux 2.png (119.53 KiB) Viewed 3943 times
Mega Games Pack for Linux 3.png (117.71 KiB) Viewed 3943 times
http://www.lastos.org/team/LastOS/mgp/r ... -11.tar.gz
Installation Instructions
Extract the archive downloaded from the link above and run the file install in terminal.
Once the installation is finished, you will be able to launch MGP from desktop shortcut or from main menu.
The first time you run MGP, it will take approx 60 seconds to scan your computers games. When you run it again it'll use a local cached database and load almost instantly.
via : http://ubuntuforums.org/showthread.php?t=1858387
Re: Play Hundreds of Free Games on Ubuntu
Postby te_lanus » Wed Nov 02, 2011 7:28 am
Me wonder if it'll run wine-based games
Postby crustyasp46 » Wed Nov 02, 2011 1:25 pm
te_lanus wrote:Me wonder if it'll run wine-based games
Apparently, the guy who has made this, also has a mega pack for wine. I have not checked it out, but if you follow the forum lead and read through the threads you can get further leads. The thrills of exploring the WWW :!: :freakout: :hi:
Postby crustyasp46 » Wed Nov 09, 2011 8:50 pm
UPDATE
Mega Games Pack WINE/Windows (Online Edition)
With the Custom Games installer and the Games Launcher to categorize, show screen shots, descriptions and a direct link to the homepage, you will be finding out about the games before you even start them. The Launcher makes it simple enough to find and run games that your 4 year old will be happy to use it.
All the games in this pack are Open Sourced or Freeware, this means you can share this disk with anyone legally. All of the games have been tested to work with Ubuntu Linux with WINE, Windows XP and Windows 7 x64 but should work fine for any Microsoft XP and above Operating System. Many of the games are low end, so any PC from all ages and graphics can run them, the few included that require a higher end system only take up a little amount of disk space so you can install every one of the games and ignore the ones that do not work, without them using any system resources.
All the games are created to be semi portable using LastOS very own Permanent Portable Games (ppGames) system, these will automatically sort shortcuts in to your start menu and if you need to re install they can be installed/stored on a separate drive and by using SetupS Control panel to re integrate the Shortcuts (terminal: wine "/home/$USER/.wine/drive_c/Program Files/SetupS.SendTo/SetupScp.exe") just pick the Preferences tab and tick ppGames then press 'Okay'. None of the games require uninstalling, if you no longer want a game on your PC, simply browse your HDD and delete the folder with the game inside.
To set the games to install to a separate drive to Windows, simply press the Options button and change the ppGames Drive letter. Please note that hiding items will un-check them if made visible again. The ssWPI installer has the power to detect games you already have installed and hide them from the installer.
If you install the Games Launcher you will be able to use it to view/find your games to pick one to play, the launcher also allows you to add games to a favorites category so you can quickly put all your favorite games into one easy to find place. The Games Launcher also includes Database Technology that will allow you to instantly start the Games Launcher without needing to scan your PC for new items, there is a "(Re)Scan Games" button on the Launcher context menu to preform this task. To add new games you must learn about SetupS Builder from Team LastOS
* You MUST have WINE 1.3.30+ installed for Free MGP to work in Linux *
Get the Latest WINE from WineHQ Downloads, to setup the PPA:
http://www.winehq.org/download/ubuntu
You have two options to begin installing the games, even tho the first option is shorter, it doesn't give you all the extras that Option 2 does (Desktop shortcut, SetupS tools, extra runtimes):-
Option 1:
Download the .zip version below and extract it to your desktop or home folder.
http://www.lastos.org/team/Public/MGPs/ ... taller.zip
You can then run the 'Installer' by double clicking on 'ssWPI.exe'
Option 2:
Download The latest 'SetupS Sendto Suite' from the pinned thread in the link below:
http://www.lastos.org/index.php?forums/setups.6/
Install SetupS by Double Clicking the 'SetupS.SendTo.Suite_v8.11.10.0_ssApp.exe' file in your '~/Downloads/' folder, this will install SetupS. You can read more about SetupS at http://www.LastOS.org
Then Download the .apz version below:
http://www.lastos.org/team/Public/MGPs/ ... _ppApp.apz
Double click 'Mega.Games.Pack.Installer_ppApp.apz' in your '~/Downloads/' and SetupS will install it and place a shortcut to 'Games Installer' on your desktop and in your menu.
if you do not wish to use the 'Installer' you can manually download a game from the Repository: (http://www.lastos.org/team/LastOS/FreeMGP) and SetupS 'SetupS Sendto Suite' can install them directly by double clicking on the downloaded .pgz games.
Extras: (This requires you have SetupS installed, '.apz' are like '.pgz' but for applications)
http://www.lastos.org/team/Public/MGPs/ ... _ssApp.apz
Many games have required extras to be installed before they work, this is a collection of:
* OpenAL
* Fonts
* PhysX 9.10.514
* VC Redist 2005
* VC Redist 2008
* Kels Runtimes (For many games)
* Games for Windows LIVE 3.1 (Allows offline mode)
* XNA Framework 3.1 and 4.0
* Adobe Shockwave Player 11.6.1.629 Slim (only works in 32-bit browsers)
* Adobe Flash Player 11.0.1.152 ActiveX (32-bit) - for Internet Explorer browser
* Adobe Flash Player 11.0.1.152 Plugin (32-bit) - for Firefox and Opera browsers
Once you have the installer on your OS your able to run it, pick games to install by browsing through the online repository.
* I recommend you install 'Games Launcher' *
Games Launcher:
You will find this in the 'Other' Category of the 'Games Installer', it will place a shortcut on the desktop and in the menu for 'Games Launcher', the 'Launcher' allows you to view the same information for the WINE/Windows games you've already installed from the 'Installer', but allows you to Launch them directly and with the StartWait Technology -
StartWait:
A tool I made that if a game crashes/stops or wont close it gives you an easy option to recover your desktop, simply pressing Ctrl + Break will close ANY game (Global Hotkey) and if the desktop resolution is detected as different to when the game was ran it'll switch it back to the original size again. It is also displayed in the System Tray (near the clock), for the times you've alt tabed out of a game and it wont go back in to it.
If you wish to backup the downloaded games, they are placed in '~/.wine/drive_c/windows/LastOS/mgprepository', You can either place them back there or place them in '~/.wine/drive_c/ppGamesInstalls'
You can place the whole lot on a USB/DVD/Folder and it will be portable to install/use in Windows or Linux:
/Mega.Games.Pack.Installer/(Put the installer here)
/ppGamesInstalls/(Put all the .pgz here)
So long as the 'ppGamesInstalls' folder is in a parent folder of 'Mega.Games.Pack.Installer' it will detect the '.pgz' (games) you include inside it. The screenshots and Descriptions are part of the .pgz so they do not need to be included. If you choose this method you must (Re)Scan the items if you add or remove any '.pgz' from the 'ppGamesInstalls' folder, we use a Database/Cache to speed up loading The installer and the Launcher.
When you install a '.pgz' they will install to '~/.wine/drive_c/ppGames', if you have more than Drive C: (winecfg or using Windows), then you can use the 'Games Installer' Option screen to change which drive the games will be installed to, this comes in handy for windows users who need to re-install their OS.
* (Re)Scanning when you make changes to your installed games or 'pgz' you include in a 'ppGamesInstalls' folder is the only way they will be shown/available from the 'Installer/Launcher' *
(Re)Scan is a Context Menu item in the 'Installer/Launcher'.
SetupS comes with the tools and help needed to make your own Games compatible to include in '/ppGamesInstalls', the tools is called 'ssEditor', SetupS will place a 'Fix_SetupS_Linux.bash' on your desktop when you install it, by making this script execuatble (Properties Context Menu in Nautilus), and running it, you will get 'Scripts/SetupS' and 'Scripts/ssEditor' in your Nautilus context menu. This will allow you to easily edit/make '.pgz'.
Special Thanks to:
http://www.caiman.us/
http://games.softpedia.com/
http://www.indiegames.com/
http://www.gametop.com/
http://www.freegamepick.com/en/
http://www.nowstat.com/
http://www.acid-play.com/
http://www.brothersoft.com/games/
http://www.freewarefiles.com/category/games.php
For providing Download Links, Descriptions and Screenshots to many included games.
And of course, the games creators/artists/testers for their passion and time making these games exist.
304 Windows & WINE compatible games:
Screen shots: http://imageshack.us/photo/my-images/23 ... ncher.jpg/
Source : http://www.lastos.org/releases.html
