Security and Your Hard Drive
Postby crustyasp46 » Mon Sep 05, 2011 8:46 pm
MIT researchers uncover mountains of private data on discarded computers
January 15, 2003 *** NOTE DATE***
CAMBRIDGE, Mass.--Discarded computers, even those with "erased" disk drives, may harbor confidential information such as credit card numbers and medical records, two MIT graduate students found.
Scavenging through the data inadvertently left on 158 used disk drives, the students at MIT's Laboratory for Computer Science found more than 5,000 credit card numbers, detailed personal and corporate financial records, numerous medical records, gigabytes of personal email and pornography.
The disk drives were purchased for less than $1,000 from eBay and other sources of used computer hardware. Only 12 were properly sanitized.
"There are many stories in which somebody has bought a used computer and found confidential information on it, but nobody has ever quantified the scale of the problem," said Simson Garfinkel, one of the students. "So we decided to find out."
Results from the study, which Garfinkel performed with Abhi Shelat, are being published in the January/February 2003 issue of IEEE Security and Privacy. The research suggests that the secondary market is awash with confidential information, although work needs to be done to get more accurate statistics. More than 150 million disk drives were retired from primary service in 2002.
Of the disk drives acquired, 129 were functional. Of these, Garfinkel and Shelat found 28 disk drives in which little or no attempt had been made to erase any information. One of these drives, Shelat says, had apparently come from an automatic teller machine in Illinois and contained a year's worth of financial transactions.
Attempts to erase information from the drives were usually ineffectual. On many disks, files that would typically be found in the "My Documents" folder had been deleted, but they could be recovered using a simple "undelete" utility. Undelete programs work because deleting a file does not actually overwrite the blocks on the computer's disk that are used to hold the file's information.
Roughly 60 percent of the disks were formatted before they were sold, but even formatting did not properly sanitize a disk because the Windows "format" command doesn't actually overwrite every block--"the format command just reads every block to make sure that they still work," Garfinkel said. "To properly sanitize the hard drive, you need to overwrite every block."
On one of the "formatted" disks, Shelat found more than 5,000 credit card numbers.
Roughly 45 percent of the disks contained no files at all and the disks could not be mounted on the computer. Yet the data could still be retrieved by reading each block of the disk using special tools.
This article made me think of the relevancy of this article in respect to those wiping programs that seem so prevalent today assuring you that any personal data will be destroyed if you use their program. Well it seems that all these assurances by respective software makers is some what lacking in credibility.
From what I have been able to gather , it seems that recovery methods of wiped data is still ahead in the game.But never fear, for those paranoid and extremely cautious. I was able to dig up a program that will completely destroy your data so it will never fall into the hands of those criminal minded thugs or those government agencies that want to pry into your every orifice.
This program was created because of the above article in 2003, and ladies and gentlemen, I assure you it is as effective today as back then.
Because of monthly bandwidth restrictions, I am unable to bring screenshots, so I will point you in the direction of this wonderful and reliable program.
Without further ado, I present>>>>>>> DriveSlag>>>>>>>
http://eecue.com/c/driveslag
Re: Security and Your Hard Drive
Postby Kherr » Tue Sep 06, 2011 2:15 am
That's why I delete my personal information with a shredder tool in accordance with the US DEPT. OF DEFENSE. :3
2 repetitions and allocating space. :3
Users browsing this forum: No registered users and 32 guests
